I've installed ODK aggregate 1.4.15 and received the token. However, when I try to upload to app-engine I receive the error
java.lang.IllegalArgumentException: MALFORMED
Unable to update app: MALFORMED
This happens following the creation of the staging directory. I've pasted the log file below
Aggregate 1.4.15 on Windows 8.1 uploading to GAE
... try uploading aggregate from my computer?
I've tried:
Logging out of google and opening the token link in a private browsing window
Allowing unsecure apps on G-suite
Using a different internet connection (for possible firewall problems)
Setting up a new GAE project and reinstalling Aggregate on my local machine with the new project's attributes
Disabling firewall and antivirus
Here's the log:
Unable to update:
at java.util.zip.ZipCoder.toString(Unknown Source)
at java.util.zip.ZipInputStream.readLOC(Unknown Source)
at java.util.zip.ZipInputStream.getNextEntry(Unknown Source)
at java.util.jar.JarInputStream.getNextEntry(Unknown Source)
at java.util.jar.JarInputStream.getNextJarEntry(Unknown Source)
at com.google.appengine.tools.admin.Application.checkJavaJarVersion(Application.java:1536)
at com.google.appengine.tools.admin.Application.checkJavaVersion(Application.java:1513)
at com.google.appengine.tools.admin.Application.copyOrLinkFile(Application.java:1438)
at com.google.appengine.tools.admin.Application.copyOrLink(Application.java:1417)
at com.google.appengine.tools.admin.Application.copyOrLink(Application.java:1406)
at com.google.appengine.tools.admin.Application.copyOrLink(Application.java:1404)
at com.google.appengine.tools.admin.Application.populateStagingDirectory(Application.java:884)
at com.google.appengine.tools.admin.Application.createStagingDirectory(Application.java:776)
at com.google.appengine.tools.admin.AppAdminImpl.doUpdate(AppAdminImpl.java:578)
at com.google.appengine.tools.admin.AppAdminImpl.update(AppAdminImpl.java:65)
at com.google.appengine.tools.admin.AppCfg$UpdateAction.execute(AppCfg.java:1526)
at com.google.appengine.tools.admin.AppCfg.executeAction(AppCfg.java:393)
at com.google.appengine.tools.admin.AppCfg.<init>(AppCfg.java:216)
at com.google.appengine.tools.admin.AppCfg.<init>(AppCfg.java:116)
at com.google.appengine.tools.admin.AppCfg.main(AppCfg.java:112)
com.google.appengine.tools.admin.AdminException: Unable to update app: MALFORMED
at com.google.appengine.tools.admin.AppAdminImpl.doUpdate(AppAdminImpl.java:586)
Caused by: java.lang.IllegalArgumentException: MALFORMED
... 6 more
