Allow counter appearance for decimal question with step
Allowing enumerators to quickly and accurately count decimals with pre-known parameters. In my case, I'm counting bricks and there can only be a full brick or half brick. The documentation for the Counter appearance says it can only be used with integer questions.
Based on current designs for the range and integer widgets, I would basically want to make a hybrid. What makes most sense to me is allowing the decimal question to use the counter appearance and giving more details in the parameter column like: start=0;end=10;step=0.5
It wouldn't NEED the start and end values, but I suppose you could include them. If parameter just had step=0.5, that would mean that a user taps the plus and it adds 0.5 instead of 1 as it currently does in the integer question.
Since most real world counts are discrete, this is a special case and I would suggest you improvise by having two counter widgets on the same screen. The first ounter used for counting full bricks (you can even include icon/image of full brick alongside the counter. The second counter to be used for counting half a brick(include image of half a brick as well). Then use calculate question to divide the cumulative count of the second counter by 2 then add it to the first counter question. I hope you may find this a workaround useful.
