in general, any android device will work. what you gain with a fancier
device is often more powerful processors, a better touchscreen, a
better camera, super accurate gps, etc. i haven't tested the ideos,
but i bet it will work perfectly.
in the future, please send such questions to the mailing list (cc:ed).
we prefer you use the mailing list because it reduces duplication and
allows the entire community to answer questions in a publicly viewable
and searchable way.
if you do get a chance to test on the ideos, can you report back to
the list so others know what the experience is like?
yaw
On Thu, Feb 17, 2011 at 22:25, Mithoefer, Klaus wrote:
> I would like to use the ODK in Kenya for field surveys, but I am new to
> Android phones. We can get Huawai Android (Huawei Ideos, Huawei VF 845) now
> here quite affordable http://www.safaricom.co.ke/index.php?id=1023 . Are
> they usable for the ODK or do I need a Smartphone with an external keyboard
> like this http://en.wikipedia.org/wiki/Motorola_Droid
I have used the ideos in Kenya successfully. The only issue noted on this
list is that odk proper doesn't appear in the market on thus phone (though
variants do). It's easy enough to download via a link. The 845 is even
harder, market isn't actually loaded onto that phone, I haven't successfully
got odk working on that phone, though I haven't actually tried very hard
Matthew
hi klaus,
and searchable way.
yaw
now
keyboard
what happens if you download the apk directly to the 845. does it
throw any sort of error message? where does it fail?
yaw
> got odk working on that phone, though I haven't actually tried very hard :-)
> Matthew
> hi klaus,
> and searchable way.
> yaw
>> now
>> keyboard
To clarify: the 845 is tricky to to use any APKs because of the
lack of a market app (apparently you can take it to Safaricom to get
Market loaded) and because the config to download non-market sources
is disabled and not in the usual place. I tried to load external APKs
while i was in Nairobi and failed: my later attempts to load it from a
PC in South Africa failed because its also networked locked. I've
since given up I don't have any reason to believe that the 845 can't run ODK but its a pain to configure. So its more of a buyer's
caveat than a bug report for ODK
Matthew
On Fri, Feb 18, 2011 at 4:41 PM, Yaw Anokwa wrote:
> matthew,
> yaw
>> Matthew
>> hi klaus,
>> and searchable way.
>> yaw
>>> now
>>> keyboard
Matthew de Gale
Programme Manager: magrica.com
SANGONeT: Mobile Agriculture Services for Africa
Phone: +27 11 381 3408
Mobile: +27 79891 0129
Mobile (Kenya): +254 717 740812 matthew@magrica.com /matthew@sangonet.org.za
sometimes the carriers don't play nice and lock down the phones.
fortunately, there are ways to get around the locks.
i haven't tried these, and they do require some technical expertise,
but they should work just fine.
yaw
On Fri, Feb 18, 2011 at 07:05, Matthew de Gale wrote:
> To clarify: the 845 is tricky to to use *any* APKs because of the
> since given up ;-) I don't have any reason to believe that the 845
> *can't* run ODK but its a pain to configure. So its more of a buyer's
> caveat than a bug report ;-) for ODK
> Matthew
>> matthew,
>> yaw
>>> Matthew
>>> hi klaus,
>>> and searchable way.
>>> yaw
>>>> now
>>>> keyboard
> Matthew de Gale
