I have a select_one question with a minimal appearance. I was wondering if it was possible to put the dropdown box next to the label so that the question only takes up one line instead of two lines.
Thank you,
Ryan
Thank you,
Ryan
Hi Ryan,
Short answer: No.
Long answer: You can customize ODK Collect to do this or try ODK
Survey, but it's not production ready.
