Hi
I'm looking for someone with a Huawei device who would be able to reproduce the crash mentioned in https://github.com/getodk/collect/issues/3887 it should take place immediately once you click Configure via QR code
from the main screen (you need to open the menu ⋮) and you grant camera permission.
We want to add the fix to the point release but we are not able to confirm that the fix works since it's a Huawei bug.
Hi
No crash
Huawei mate 10 pro
I didn't uninstall odk. I just turned off the permission in settings of my device and then I made the video
Thanks for checking @Dominik1
The crash might occur only on Huawei devices but not on all models so apparently your one is free of that bug.
HUAWEI P10 PLUS works fine. No crash. ODK Collect was reinstalled.
Evidence:
Thanks @Alexander_Torrado
I don't know about all affected models but it should be visible at least on:
- HUAWEI Y5 2018
- HUAWEI Y5 lite 2018
- HUAWEI GR3
Works OK on 2016 Huawei Y3II LUA-L02 (Lollipop 5.1) with clean install of ODK Collect v1.27.0
