App Engine setup region/location
Hello Imran, when I'm in Africa which region should I use for configuring App Engine?
Hi Abdoul,
Good question! I believe you can select the region closest to you. You may select Europe. I use ODK for the projects in Southern African Region and I have selected us-central for configuring App Enging.
Imran
Okay, thank you Imran.
