Appearance 'image-map' and SVG types
SVG behaviour is different in Enketo and ODK Collect and default SVGs don't work properly.
  • Enketo
    • Using the SVG code from the docs, only the path (blob) is selectable in Enketo
    • Creating an SVG in Inkscape behaves the same, rectangle/ellipses can't be selected. Putting them in a one element group and applying the ID to the group does result in the label displaying and opacity changing on mouseover but it's still non selectable
  • Collect
    • With the SVG code from the docs, all elements are selectable, and all revert to original colour when selection changed
    • Creating an SVG in Inkscape has selectable elements (including non paths), however changing the selection changes the previously selected element as a solid black fill
    • Putting an element in a group does allow it to be selected but doesn't change the colour on select or deselect so visual confirmation is less positive
  • ODK Central 1.3.3 (client 1.3.2)
    • Windows 10 Enterprise 1909
    • Edge Version 96.0.1054.43 (Official build) (64-bit)
    • Chrome Version 96.0.4664.45 (Official Build) (64-bit))
  • ODK Collect 2021.3.2
    • Android 11
    • Samsung Galaxy Tab S6
  • Inkscape
    • Linux v1.1.1
    • Windows v0.92.4
  • When saving the SVG, use 'optimised SVG' with these options selected
    • Options
      • Shorten colour vales
      • Convert CSS attributes to XML attributes
      • Collapse groups
      • Create groups for similar attributes
      • Work around renderer bugs
    • SVG Output
      • Remove the SML declaration
      • Remove the metadata
      • Remove comments
      • Embed raster images
      • Enable viewboxing
      • Format output with line-breaks and indentation
  • As above in (1)
(3) fixed the issue for me, but if there is additional documentation / guidance on best practice for SVG creation for ODK use I would be keen to understand it better.
I couldn't find much on this by searching so I hope it helps someone else with the same problem in the future.
Can you give an short example of this? I wasn’t getting this behavior in Enketo.
See the other thread for an example form / svg
