I am getting error:
"A problem has occurred that prevents your AppEngine application from responding. Your application may have exceeded its per-minute or daily usage quotas.
... " See attached file to see the complete error.
I don't know why is this happening. My usage history seems fine to me. Any help or suggestions would be much appreciated.
Usaid.
First, go to your appengine dashboard (https://appengine.google.com/ ),
click on your Application ID, and see if the Billing Status shows any red
usage bars. If it does, you have exceeded your usage quota for the day.
Quota limits are daily limits and are reset at midnight Los Angeles, CA
time.
If it doesn't show red, then verify that you are still having problems
accessing the web server. Because it resets daily, you may have exceeded
quota yesterday.
A more unlikely possibility is that your server access is "throttled". This
occurs if there is a spike in accesses to your server during an short time
interval. It is intended to prevent attackers or faulty client programs
from burning through your daily quota.
If this is happening upon first setting up this appEngine instance, try
re-uploading the software to appEngine; you don't need to re-run the
installer to do this, just navigate into the directory you specified in the
installer, and double-click on the 'uploadAggregateToAppEngine...' file. I
have seen a few instances where the install of software was not 100%
successful.
Otherwise, you can invite me as a developer to your AppEngine instance and
I can look in the log files to see if there is anything else going on.
https://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
On Thu, Mar 12, 2015 at 11:12 PM, wrote:
I am getting error:
usage quotas.
Usaid.
