I have been you using ODK aggregate server to store the data over Google Cloud. However, I tried to login after I had successfully logged-in earlier using two different accounts but a few minutes ago, I tried to login but I received the following error
AppEngine Application Problem
A problem has occurred that prevents your AppEngine application from responding. Your application may have exceeded its per-minute or daily usage quotas.
Please visit your application dashboard at Google AppEngine. The Billing Status section will indicate what daily or per-minute usage limits your application has exceeded.
If your application's usage limits have not been exceeded, then look for performance issues within Google AppEngine cloud services. From your application dashboard, click on the the System Status link on the left sidebar under the Resources heading. This will report problems with Google AppEngine cloud services.
If neither of those indicate any problems, then your application's Logs may; these are reachable from the dashboard via the Logs link on the left sidebar under the Main heading.
I have interviewers who are in the field and are currently carrying-out the survey. I followed the link on AppEngine and found a warning on Datastore Read Operations that its currently experiencing short-term quota limit.
Kindly assist me on how I can get the account back and what could be the problem.
As it explains in the error message, you are probably out of quota. "Please
application has exceeded." Wait 24 hours for quota to reset or add a credit
card and enable billing.
Need ODK services? http://nafundi.com provides form design, server setup,
professional support, and software development for ODK.
usage quotas.
limit.
problem.
I am trying to export my information, but i have a message that say Quota Exceeded. I wait the next they the informatio is there but i cant export. A dont know what happen i only access one time.
See
https://opendatakit.org/use/aggregate/deployment-planning/#AppEngine_Usage_Fees
for information on how quota can be consumed.
If you have a publisher that is failing, this can also cause it to burn
through quota.
If you are certain that you are not doing anything to cause the quota to be
consumed rapidly, you can invite mitchellsundt@gmail.com as a developer on
your AppEngine application ID and I'll look at the error logs.
https://github.com/opendatakit/opendatakit/wiki/Aggregate-AppEngine-Troubleshooting#inviting-someone-to-be-a-developer
