Is there any way to integrate SQL (postgreSQL, MySQL or any SQL) to ODK
Aggregate? We're hoping to merge several data sets from multiple (but
similar ODK forms) from several of our field offices so as to avoid
downloading each data set for every office at a time. This becomes tedious
when we're handling several different forms.
You can then set up publishersin ODK Aggregate for each of your field
office forms to publish into that one single downstream server.
And because you wrote that server, it can store the data in whatever
database representation you need.
Alternatively, if you host your own server, you could define a view across
the tables to consolidate the data sets, but would need to use MySQL tools
directly to use that for analysis.
On Thu, Nov 13, 2014 at 10:45 PM, Ramadhan Ali Swalleh < ramadhan.swalleh@evidenceaction.org> wrote:
Hi Everyone!
