Assigning respondent to enumerator
Hi All,
I have a project whereby I need to survey 15,000 respondents (predefined list of household in a city) and have 100 enumerators to perform such survey.
Anyone here have any idea on:
  1. How we can preload the survey with the basic information of each respondent (name, address, phone number), and
  2. Assign certain numbers of respondent to each enumerator?
For example: as I have 15,000 respondents and 100 enumerator, then I would fairly split the load to 150 respondents for each enumerator.
Many thanks for all the kind help.
Fandy
Hi Fandy,
ODK Tables and ODK Survey were designed for these use cases.
Unfortunately, both apps are in alpha and are not field ready.
Your alternative is to hire a developer
(http://opendatakit.org/help/help-for-hire/) to build an Android app
that does the preloading and assignment.
ยทยทยท -- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.
On Mon, Oct 21, 2013 at 11:03 AM, fandy.santoso86@gmail.com wrote:
Hi All,
Fandy
Hi Fandy,
SurveyCTO (www.SurveyCTO.com) supports pre-loading data.
However, it has no built-in support for enumerator management. For
assigning specific surveys to specific enumerators, we generally use a
combination of Excel and mail merge in Word. And, much in the way of
balancing work-loads in the field ends up being handled by field
supervisors. So one approach, for example, is to assign surveys to teams by
geography, then let teams sort out who does which interviews. There's
obviously a lot to field management, though, so I'm dramatically
oversimplifying.
Chris
ยทยทยท On Oct 21, 2013 2:16 PM, wrote:
Hi All,
survey.
Fandy
Hi Yaw,
Thanks for the prompt response. Do you know approximately when will ODK
Tables and Survey be released?
Please do correct if me if I'm wrong, but assuming from your answer, the
only part where it needs modification is the Android apps isn't it?
Again, many thanks for your assistance.
Fandy
Hi Chris,
Thanks for your response.
Several quick questions about SurveyCTO:
  1. Even by using Excel and mail merge function of Word, how do we appoint
    specific respondent (pre-loaded form) to each enumerator? Does SurveyCTO
    support credential login process into SurveyCTO Collect? Otherwise when we
    are downloading the survey from the server, the system cannot determine
    which enumerator is downloading which survey right?
  2. Since we are performing the survey for our client, is it possible if we
    can do white labeling and host SurveyCTO in our own server?
  3. Lastly, is it possible for us to modify the language used in the
    SurveyCTO Server, Collect and Client? I understand that we can use
    different languages in the XML (forms), but I also need to localize the
    other products as such my local enumerator and system administrator can use
    the system to its fullest capability.
Greatly appreciate your help and many thanks!
Fandy
ยทยทยท On Tuesday, October 22, 2013 7:47:37 AM UTC+7, Christopher Robert wrote: > > Hi Fandy, > > SurveyCTO (www.SurveyCTO.com) supports pre-loading data. > > However, it has no built-in support for enumerator management. For > assigning specific surveys to specific enumerators, we generally use a > combination of Excel and mail merge in Word. And, much in the way of > balancing work-loads in the field ends up being handled by field > supervisors. So one approach, for example, is to assign surveys to teams by > geography, then let teams sort out who does which interviews. There's > obviously a lot to field management, though, so I'm dramatically > oversimplifying. > > Best, > > Chris > On Oct 21, 2013 2:16 PM, <fandy.s...@gmail.com > wrote: > >> Hi All, >> >> I have a project whereby I need to survey 15,000 respondents (predefined >> list of household in a city) and have 100 enumerators to perform such >> survey. >> >> Anyone here have any idea on: >> 1. How we can preload the survey with the basic information of each >> respondent (name, address, phone number), and >> 2. Assign certain numbers of respondent to each enumerator? >> >> For example: as I have 15,000 respondents and 100 enumerator, then I >> would fairly split the load to 150 respondents for each enumerator. >> >> Many thanks for all the kind help. >> >> Fandy >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/groups/opt_out. >> >
Hi Fandy,
As I said, SurveyCTO doesn't have any features for fieldwork management.
But by pre-loading data and programming logic into your survey form, you
can do some things to support your own fieldwork management.
For example, your enumerators might start each form by entering and/or
scanning their enumerator ID (from a barcode). When it comes time to
identify the respondent, you can offer a multiple-choice list that only
shows those respondents assigned to that enumerator. If the list is too
long (150 is too long), you could start by asking about the region, then
the district, then the village, then only show their respondents in the
selected village -- or however it is most natural to narrow down that list.
It would be slightly radical, but in the pre-loaded data you could even
specify a device ID for each respondent, and then the form could
automatically filter the list of possible respondents by that device ID.
Thus, each device would show a different list. This would uniquely assign
respondents to devices, but it probably wouldn't be a great system because
of its lack of flexibility; it would be hard to re-assign respondents, for
example, if a device failed or an enumerator took the day off.
In general, fieldwork management is a complex thing. It's essentially
outside the scope of what ODK (and most ODK variations) try to directly
facilitate. But you can definitely conduct a survey of 15,000 households.
You just need to work out your own field-management practices.
As for a white-label server, we haven't offered such an option to-date. We
would consider it for the right price, but it would be expensive. If you
want to discuss it, you can email me offline.
As for other languages, the only product localized to many other languages
is Collect -- which is the only product used by field supervisors,
enumerators, etc. (You simply change the language in Android's settings.)
For the moment, the SurveyCTO Server and Client are in English only, but
then a much smaller range of people use those interfaces. We are also open
to localizing those, also for the right price.
Chris
ยทยทยท On Tue, Oct 22, 2013 at 3:09 AM, Fandy Santoso wrote:
Hi Chris,
Fandy
Hi Fandy,
oversimplifying.
Chris
On Oct 21, 2013 2:16 PM, fandy.s...@gmail.com wrote:
Hi All,
survey.
Fandy
Unsubscribe: opendatakit...@**googlegroups.com
an email to opendatakit...@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out
Dear Chris,
Your idea is wonderful to get around ODK limitations but yes it does
require a heavy load on the fieldwork management side.
Nevertheless many thanks for your kind input and information!
Fandy
Hi Fandy,
I provide a server, plus extensions to odk, that allows you to assign a
task to a user. Tasks include addressing information; latitude, longitude
and arbitrary data such as physical addresses. This allows the task to be
shown on a map on the phone and the address information shows up in a list
of tasks. The task also includes the form that needs to be completed, this
is downloaded onto the phone automatically if not already installed.
The system seems to have some of the features you are asking for, however
it will probably need some customisation in order to manage the 15,000
addresses and their assignment to users. Though thinking about it this
could be done with batch loading as all the task information is stored in a
relational database.
There is some more general information on the server in the organisational
blog: http://blog.smap.com.au/. The following You Tube video shows
assignment of tasks. http://www.youtube.com/watch?v=zuJlWIoSEhA
regards
Neil
ยทยทยท On Wed, Oct 23, 2013 at 2:43 PM, Fandy Santoso wrote:
Dear Chris,
Fandy
Smap Consulting http://smap.com.au/| Mobile Data Collection Solutions
Application Developer - neilpenman@gmail.com minqiang.huang@gmail.com
Twitter: @dgmsot
Skype: ianaf4you
Phone: +61 402 975 959
Blog: http://blog.smap.com.au http://smap.com.au/blog
