Hi every one,
there is a problem coming in ODK collect, it gives a error " attempt to invoke virtual method'java.lang.string. when i try to view my sent forms specially, it occurs.
Hi @Waqarahmadcro!
- What specific version of Collect are you using?
- Does this happen with all forms or just this one? On all devices or just this one?
- What have you tried to fix the problem?
Thanks for prompt reply.
Odk vollect Version is 1.15.1
It is happening with different forms
I tried to use simple form to test and it gives this error even
Regards
Could you attach any of those affected forms? Did you try forms from the demo server?
<a class="attachment" h
Got it, thanks a lot, you provided very helpful information. I reproduced the issue and I'm working on a fix.
Thanks, hopefully it will be fixed. Please inform when it is fixed
Thanks for the quick fix, @Grzesiek2010! @Waqarahmadcro v1.16.1 has the fix and is currently rolling out.
Thank you so much. the issue is resolved in new update.
