I am new to odk so bare with me if this is incredibly simple.
I am trying to assign a unique ID to each repeat based on parent information and the sequence of repeat.
To explain, attached is a simple example of repeats from XLSform. I messed with the settings part to try to assign a unique ID to each repeat by using instance_name but it simply assigns a unique ID to the overall parent form. If that makes sense.
I want each repeat to have a unique ID associated with it's data that would essentially be today_placeofdelivery_sequenceinrepeat in this example. [Sequence in repeat being (1, 2, or 3 etc.)]. That way when its exported I could look up an ID and see the info attached with it.
When I export the data, however, I do not see unique ID's for the repeat, and instead for the whole form.
If you want to get the position of a repeat, use 'position(..)'
If you want to generate a truly unique ID or a repeat, use 'once(uuid())'
For both options, store the value inside a calculate field and put the
methods (e.g., position(..)) in the calculation column.
Try that and let us know how it goes,
On Mon, May 22, 2017 at 5:35 AM, wrote:
> Hi,
> Thanks,
> Arram
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
However, I would like the position number to have 4 digits, with leading zeros. so it would look like:
05292017-PlaceX-0003
I tried using regex() but it wouldn't work for autogenerate numbers like the position. any other ideas?
THanks,
Arram
On Monday, May 22, 2017 at 6:58:20 PM UTC+1, arramno...@gmail.com wrote:
> Hi,
> Thanks,
> Arram
How would you use this uuid to retrieve a specific variable's value in one
specific repeat?
I want to apply this to put a constraint that each new value (i.e. in each
new repeat) of a variable must be smaller that the previous value (i.e. in
previous repeat) of the same field.
Best regards
On Thursday, 25 May 2017 16:34:36 UTC+2, Yaw Anokwa wrote:
> Hi Arram,
> Yaw
> On Mon, May 22, 2017 at 5:35 AM, <arramno...@gmail.com > wrote:
> > Hi,
> > Thanks,
> > Arram
> an email to opendatakit...@googlegroups.com .
If you need leading zeros, then using position(..) alone won't work.
You need to build up the string yourself.
I haven't tested this, but I'd have a calculate prompt with a
calculation like this:
if(position(..) > 9, concat('00', position(..)), concat('000', position(..)))
If the number is > 9 (so 2 digits), then store '00' + the number (e.g., 0020)
If the number is < 9 (so 1 digit), then store '000' + the number (e.g., 0008)
Hope that helps,
>> Hi,
>> Thanks,
>> Arram
> Hi Yaw,
> Thank you.
> I was able to use position(..) to assign each repeat a number. I then used concat to generate a full ID for each repeat that is like
> today_placeofdelivery_position(..)
> 05292017-PlaceX-3
> THanks,
> Arram
For constraints across repeats, I've attached a sample form that does
that for dates that might help. For the date constraint, you can use
indexed-repeat and position to capture the date of the previous
repeat. Then use relevancy to show a note when the date is out of
bounds. If that note is made required, it won't let the user proceed.
You should also only show this note when the number of repeats is
greater than 1 because the first date has nothing to compare against.
On Sat, May 27, 2017 at 2:06 PM, Souirji Abdelghani wrote:
> Hi Yaw,
> specific repeat?
> Best regards
>> Hi Arram,
>> Yaw
>> > Hi,
>> > Thanks,
>> > Arram
>> > an email to opendatakit...@googlegroups.com.
On Sunday, 28 May 2017 22:04:55 UTC+2, Yaw Anokwa wrote:
> Souirji,
> You wouldn't use the UUID to retrieve a specific value.
> indexed-repeat() and position() is still the best way to do that.
> https://groups.google.com/d/msg/opendatakit/M_pERTptaA4/ltWOFzpWCQAJ
> has a good example of how you can use it.
> Yaw
> On Sat, May 27, 2017 at 2:06 PM, Souirji Abdelghani <ghani...@gmail.com > wrote:
> > Hi Yaw,
> one
> > specific repeat?
> each
> in
> > Best regards
> >> Hi Arram,
> 'once(uuid())'
> >> Yaw
> >> > Hi,
> repeat by
> parent
> example.
> exported I
> >> > Thanks,
> >> > Arram
> send
> Groups
> an
