Hi Piqo,
Find attached the python script and config files as promised.
Full steps for use are:
o Create your form and load it onto a device
o Ensure ODK Collect is not connected to the internet
o Fill Blank Form and complete the form you loaded. At the end Save and
Finalize
o Use OI File Manager (app from Play Store) to zip the /odk/ folder on your
device
o Copy the zip file to your computer
o Unzip the folder. Navigate to the /instances/ folder.
o There should be a subfolder generated by your submission, something like
_date_time
o Inside this folder you will find the xml file from your submission, as
well as any media files (e.g. photos)
o This is the structure you need to replicate using the scripts
Details of the scripts:
o settings_test.json: this is just a config file (saves me using a bunch
of command-line paramaters)
o numsubmissions - how many submissions to generate. Max value of 999
in this case
o submdate - simulated date of submission
o outputpath - folder to create for files output by scripts
o all other values were specific to my application - I have left them
as an example. I needed a unique sequential number which incremented with
each submission for my testing.
o last_uuid.json: keeps track of the last_uuid generated for the
submissions, for repeated running of the script. Is updated with each run.
I just started the uuid at 0000.....00 and incremented it with each
submission. Only requirement is for them to be unique so I didn't bother
making it any more complex than that.
Similarly, I set the submission time as 1 second apart for each submission,
just to get some spread.
Using the scripts:
o Modify the create_submission_file() function in the script to set values
as you need.
Note that if values are stored at root level then root.find() will find
them directly
If they are within a group (like 'grp_personal_1' in my script) then you
must first find the group, and then find with that 'node' for the fields
stored in the group.
o Make a copy of your example xml file and save it as
template_submission.xml
o If you have a media file that you want submitted, create a suitable
subfolder and example file (see FOLDER_PHOTO_TEMPLATE and PIC_ID in the
script)
o edit settings_test.json as desired
o run the script using:
python genSubmissions.py settings_test.json
o Cut and paste the folders from output_path into the /instances/ folder
mentioned above (or modify the script to write there directly
o Pull these submissions into ODK Briefcase, either via the GUI or from cmd
line:
java -jar "ODK Briefcase v1.4.5 Production.jar" -id MyFormID -od
"C:\ODKtesting\test_files\test_odk" -sd "C:\ODKtesting\Briefcase"
od = unzipped odk directory
sd = Briefcase storage directory to create/use
o Now use the Briefcase GUI to push the forms to your instance
(unfortunately no cmd line way to do this). In my case I was using a VM for
my testing.
Hope that's of some use!
Regards,
Andrew
last_uuid.json (16 Bytes)
settings_test.json (214 Bytes)
genSubmissions.py (4.55 KB)
On Thursday, 19 May 2016 11:06:32 UTC+2, Andrew wrote:
> Hi Piqo,
> The approach was to use an example submission for that form as a template
> for submissions.
> To generate new submissions I just edited (programatically) the fields I
> wanted to set specifically.
> This was done using a python script:
> o Read the copied template xml file into memory using lxml library (from
> lxml import etree)
> o Search the xml tree for the specific fields that need to be changed and
> set these values
> o Write the xml tree out to file
> I'll post the script here for you a bit later today.
> Regards,
> Andrew
> On Wednesday, 18 May 2016 13:48:30 UTC+2, El Piqo wrote:
>> Hi Andrew,
>> I'm curious to know, how do you generate the XML programmatically? (I
>> mean valid XML that follow the form's logic (skips, etc)"
>> Any library that can help me with that?
>> Best,
>> piqo
>> On Saturday, May 14, 2016 at 11:41:53 PM UTC+2, Andrew wrote:
>>> Thanks Mitch, this did the job.
>>> Regards,
>>> Andrew
>>> On Thursday, 5 May 2016 20:58:23 UTC+2, Mitch Sundt wrote:
>>>> There is no import-csv functionality. You would need to generate XML
>>>> files.
>>>> The easiest import is to copy the directory structure of ODK Collect
>>>> from a device, then direct ODK Briefcase to pull from that directory
>>>> structure (after placing the form definition in the proper directory and
>>>> creating the instance folders and instance files).
>>>> Once you have loaded an ODK Briefcase with data, it can then be pushed
>>>> to ODK Aggregate. The push mechanism uses the same
>>>> filled-in-form-submission process as ODK Collect.
>>>> It is best if you generate a unique instance ID for each record. If you
>>>> don't, ODK Aggregate will synthesize one. During the push from ODK
>>>> Briefcase, ODK Briefcasewill update the submission XML file with additional
>>>> root element attributes to record the instance id that ODK Aggregate
>>>> assigned to it. This prevents multiple uploads of that record by multiple
>>>> runs of this ODK Briefcase (so you gain nothing by not specifying an
>>>> instance id yourself).
>>>> On Thu, May 5, 2016 at 4:21 AM, Andrew wrote:
>>>>> Dear ODK team/community,
>>>>> I have a data system which makes use of ODK for the data gathering
>>>>> portion.
>>>>> As part of testing the system it would be very useful to automatically
>>>>> (programmatically) generate large amounts of submissions data and submit it
>>>>> to an Aggregate instance (e.g. using Python scripts)
>>>>> I would appreciate some guidance as to the easiest/quickest way to do
>>>>> this.
>>>>> It is easy enough to generate a csv file containing test submission
>>>>> info, or to generate multiple xml submission files from a template.
>>>>> What are the options for pushing this data to an Aggregate instance?
>>>>> Some older posts suggest that using Briefcase is the way to go with
>>>>> this - is this still the best option?
>>>>> Do I only need to copy the xml files into Briefcase storage folder, or
>>>>> does it need other info/files?
>>>>> Do I need to generate the unique uuids, or are they generated as part
>>>>> of the submission process?
>>>>> Is there any way to import csv data into Briefcase for pushing to
>>>>> Aggregate, or must it be in the xml files?
>>>>> Thanks and regards,
>>>>> Andrew
>>>>> Post: opend...@googlegroups.com
>>>>> Unsubscribe: opendatakit...@googlegroups.com
>>>>> Options: http://groups.google.com/group/opendatakit?hl=en
>>>>> You received this message because you are subscribed to the Google
>>>>> Groups "ODK Community" group.
>>>>> To unsubscribe from this group and stop receiving emails from it, send
>>>>> an email to opendatakit...@googlegroups.com.
>>>>> For more options, visit https://groups.google.com/d/optout.
>>>> Mitch Sundt
>>>> Software Engineer
>>>> University of Washington
>>>> mitche...@gmail.com
