Start-geopoin function using too much screen area. My form completley unusable for seconds.
ODK Collect 1.26.0.beta.0
Actually nothing. This is my first try.
Is it possible to make an option in the general settings, where the user can accept the auto location record and in same time the popup alert be disabled?
As You see, in my current form I'm using Select_one list with autocomplete search appearance. And that is where the problem begins.
