Hi everybody
Please is it possible for odk to Autocomplete adress from geopoint so that we can get at the end per example name of city, street number and so on... in the filled form? If yes is there a script to put into the form ,when we are building it?
The term you are looking for is "geocoding" and there's no turnkey way to do this. But once the data is on the ODK server, you can build an integration to convert those coordinates to addresses in a downstream tool.
If, for example, you are using ODK's Power BI or R integration, you can send the GPS coordinates to a geocoding service (e.g., Google's Geocoding API) and get back an address. Watch this video to learn how to geocode in Power BI and read this page to do it in R.
Related: Add geocoding reverse - method to convert a geographic location to an address in real time
Thank you very much for your reply!
