Good morning companions,
I am designing a form in ODK and I would like to know if it is possible that geolocation works as metadata.
Thank you very much, greetings
Buenos días compañeros,
Estoy diseñando un formulario en ODK y me gustaría saber si es posible que la geolocalizacion funcione como metadato.
Muchas gracias, saludos
I am designing a form in ODK and I would like to know if it is possible that geolocation works as a metadata.
Hi @jonnathanCh
No, it's not possible. As I understand you want to record location in the background? Unfortunately as I said you can't do that.
Regards,
Grzegorz
Hola Grzesiek2010, muchas gracias por tu respuesta, lo que me gustaria es que la geolocalizacion se pueda ingresar como un metadato, y no tener que crear una pregunta.
Hello Grzesiek2010, thank you very much for your answer, what I would like is that the geolocation can be entered as a metadata, and not have to create a question.
You can create a topic https://forum.getodk.org/c/features and describe how you want to use it, why it's important etc. Maybe it's something we can add in the future.
