Possible, and highly recommended. I track all surveys with beginning and end
timestamps. That way, I can know exactly how much time enumerators are
spending on surveys. Too fast is just as bad as too slow.
How do you deal with situations where someone saves the survey as
incomplete? Will the start and end timestamps be overwritten at the next
time the survey is loaded?
Luke
end timestamps. That way, I can know exactly how much time enumerators are
when you save as incomplete, we don't validate any constraints. we
also don't make the data available to send. every time you save, the
end timestamp will be updated.
On Tue, Aug 17, 2010 at 08:33, Neil Hendrick wrote:
> For us, an incomplete survey is a throwaway, so I disable all "save as
> incomplete" functions in my custom version of ODK.
> That said, I think even an incomplete survey would fill in the node
> with the exit time. Anyone else have a thought on what happens when you
> "save as incomplete"?
> Neil
> On Tue, Aug 17, 2010 at 11:30 AM, Kyohere Luke wrote:
>> Thanks Neil. Very helpful.
>> Luke
>>> How to:
>>> In your form XML, create nodes to hold the data:
>>> Then, in the BIND autofill that data:
>>> >> jr:preload="timestamp" jr:preloadParams="start"/>
>>> >> jr:preloadParams="end" />
>>> I hope that's helful.
>>> ~Neil
>>> On Tue, Aug 17, 2010 at 9:40 AM, Pr0f3t wrote:
>>>> I have two questions:
>>>> The first is whether it is possible to track some time statistics
>>>> about a survey, including:
>>>> - How long it takes to run a certain survey
>>>> - When a survey was actually run (as opposed to when the survey ended)
>>>> Having a way to grab the start and end time of the survey would help
>>>> with these two requests.
>>>> The second is whether it is possible to have a question which will
>>>> just "save" the current timestamp (Date and Time)
>>>> Post: opendatakit@googlegroups.com
>>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
>>>> Options: http://groups.google.com/group/opendatakit?hl=en
>>> ~Neil
> ~Neil
yes. we've implemented this functionality in trunk. at some point
we'll add auto-save as well.
On Tue, Aug 17, 2010 at 09:18, Neil Hendrick wrote:
> Just thinking out loud now...is there a way to save data mid-form without
> exiting the survey?
> N
>> > node
>> > Neil
>> >> next
>> >> Luke
>> >>> and
>> >>> are
>> >>> How to:
>> >>> ~Neil
>> >>>> ended)
>> >>> ~Neil
>> > ~Neil
> ~Neil
Very interesting - what about on-demand timestamp collection? E.g at
certain points in the survey, we'd like to have the user click a
button to capture the current date and time. Can this be achieved with
the jre.preload="timestamp" functionality?
Luke.
On Aug 17, 7:23 pm, Neil Hendrick wrote:
> Excellent. Auto-Save might avoid the rare but tragic "Force Close on Exit"
> crashes.
> Neil
> > > exiting the survey?
> > > N
> > >> > node
> > you
> > >> > Neil
> > >> >> next
> > >> >> Luke
> > >> >>> and
> > enumerators
> > >> >>> are
> > >> >>> How to:
> > >> >>> ~Neil
> > >> >>>> ended)
> > help
> > >> >>>> Options:http://groups.google.com/group/opendatakit?hl=en
> > >> >>> ~Neil
> > >> > ~Neil
> > > ~Neil
> ~Neil
Neil
exiting the survey?
N
node
Neil
Luke
exiting the survey?
N
node
you
Neil
next
Luke
you can't currently do it. it's pretty easy to do this in collect, but
this seems like something that should be in the javarosa-core. i'll
look into it and get back to you.
yaw
> Luke.
>> crashes.
>> Neil
>> > > exiting the survey?
>> > > N
>> > >> > node
>> > you
>> > >> > Neil
>> > >> >> next
>> > >> >> Luke
>> > >> >>> and
>> > enumerators
>> > >> >>> are
>> > >> >>> How to:
>> > >> >>> ~Neil
>> > >> >>>> ended)
>> > help
>> > >> >>> ~Neil
>> > >> > ~Neil
>> > > ~Neil
>> ~Neil
