I have three consecutive variables where the user must rank first, second and third from the same list but without duplicating any selection. Each variable has 8 select_one options
I am using XLS forms
Have tried using this on the constraints such that variable1 cannot be the same as variable2 and same applies for variable3 (. <> q15constraints_first) or(. <> q15constraints_second) Have tried
