As I understand it currently ODK Collect 1.2 is backwards compatible to Android 1.6. When you release ODK Collect 2.0 are you planning on changing the version of Android you'll be backwards compatible with?
ODK Collect 1.2 is only supports Android 2.1 onward.
ODK Collect 1.1.7 and earlier support Android 1.6 onward.
We are trying to have 2.0 backward compatible to Android 2.2, but have not
ruled out it being only available on more recent systems should we find
some critical functionality lacking in the earlier releases. The key
concern is if there were significant performance issues or bugs and reduced
capabilities of the WebKit in the 2.xsystems. e.g., http://www.quirksmode.org/webkit_mobile.html
On Mon, Nov 5, 2012 at 8:49 AM, Reed, Joshua T CIV (US) < joshua.t.reed.civ@mail.mil> wrote:
Classification: UNCLASSIFIED
Caveats: FOUO
Good morning,
the version of Android you’ll be backwards compatible with?
