I'm new to ODK and learning by creating sample forms. I have created a
sample form with barcode scanning and it works good and i can see the value
of barcode from ODK aggregate. when i tried to publish them to fusion table
the barcode value is turned blank. Also I couldn't export the form data to
csv or google spreadsheet, but aggregate is showing 'Not yet created'.
there were no other error notification.
Appreciate if someone can help me on this two issues.
The barcode should publish through OK. Do simple barcodes like UPC symbols
publish OK?
w.r.t. Google Spreadsheet or file export, we just identified a bug in the
latest ODK Aggregate (the one with the entity-key fix) that is causing
these actions to fail. We'll have a fix soon.
I have tested with UPC A barcode format but it is still not published
whereas i can see the value in ODK aggregate. am i missing something ??.
please refer to the screen shot of odk form.
> publish OK?
> Mitch
> On Tue, Aug 13, 2013 at 6:31 AM, Madhav <bblsu...@gmail.com >wrote:
>> Hi,
>> Regards,
>> Madhav
>> "ODK Community" group.
>> For more options, visit https://groups.google.com/groups/opt_out.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
On Wed, Aug 14, 2013 at 12:40 AM, Madhav wrote:
Dear Mitch,
Thanks for your reply.
Thanks for helping !.
Madhav
symbols publish OK?
Groups "ODK Community" group.
an email to opendatakit...@**googlegroups.com.
Thanks Mitch.,
I have added you as developer and site admin.
I have updated the latest release and now i can able to export form to
google spreadsheet and csv formats.thanks a lot for support.
Also, i have list of countries and list of cities in each country. how to
use choice filter for these two collections. appreciate if you could
explain in detail or with any example form. It didnt work when i tried with
format given in formhub.
Thanks!>
On Thursday, August 15, 2013 1:15:31 AM UTC+3, Mitch Sundt wrote:
> If you are running on Google AppEngine, please both add me as a Site Admin
> to your system and invite me as a developer. https://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting
> On Wed, Aug 14, 2013 at 12:40 AM, Madhav <bblsu...@gmail.com wrote:
>> Dear Mitch,
>> Madhav
>>> symbols publish OK?
>>> the latest ODK Aggregate (the one with the entity-key fix) that is causing
>>> Mitch
>>>> Hi,
>>>> Regards,
>>>> Madhav
>>>> Unsubscribe: opendatakit...@**googlegroups.com
>>>> Options: http://groups.google.com/**group/opendatakit?hl=en
>>>> For more options, visit https://groups.google.com/**groups/opt_out
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Keep in mind that the XLSForm tool provided on opendatakit.org is slightly
different from the XLSForm tool provided on formhub.
Search down for 'cascading Selects' on this page:
There is a link to an example XLS file showing how to define cascading
selects for the opendatakit.org variant of XLSForm.
On Thu, Aug 15, 2013 at 3:05 AM, Madhav wrote:
Thanks Mitch.,
Thanks!>
Madhav
symbols publish OK?
an email to opendatakit...@**googlegroups.**com.
Thanks Mitch.,
Thanks!>
Madhav
symbols publish OK?
a sample form with barcode scanning and it works good and i can see the
value of barcode from ODK aggregate. when i tried to publish them to fusion
table the barcode value is turned blank. Also I couldn't export the form
data to csv or google spreadsheet, but aggregate is showing 'Not yet
created'. there were no other error notification.
send an email to opendatakit...@**googlegroups.**com.
I have tried it again after doing some changes in the design but as per
formhub format. it is working well. But i have around 8000 rows of data in
the choices sheet which takes tooooo much time to load a form or it crashes
ODK Collect most of the time. is there any workaround to handle such a
large number of choice list ??.
Tks..
Madhav.
On Thursday, August 15, 2013 6:54:34 PM UTC+3, Mitch Sundt wrote:
> RE: Cascading selects (countries and cities)
> slightly different from the XLSForm tool provided on formhub.
> http://opendatakit.org/help/form-design/xlsform/
> Mitch
RE: barcodes not publishing to Fusion Tables or Spreadsheets
The use of the same field name ( 'cooler_no1', 'cooler_no2' ) for several
fields is the issue.
These are only distinguished by their containing groups, so you have:
When they get inserted into fusion tables or spreadsheets, we strip off the
containing groups.
We then traverse the form in the order of these data values (D1/1, D2/1,
D2/2, D3/1, D3/2, D3/3), and insert them into a list of name-value pairs
that is sent to Google Fusion Tables or Spreadsheets.
So if you have data entered for D1/1 = 'a' and D2/2 = 'b', that data will
be overwritten by the data provided for sectionD3.
In this case, the data for sectionD3 is 'no data' (an empty string).
And so the resulting published data into Fusion Tables and Spreadsheets is
an empty string.
The fix is to rename your fields so that they are unique without reference
to their enclosing groups.
Thanks Mitch.,
to use choice filter for these two collections. appreciate if you could
Thanks!>
Madhav
symbols publish OK?
containing groups.
So if you have data entered for D1/1 = 'a' and D2/2 = 'b', that data will be
an empty string.
Thanks Mitch.,
Thanks!>
Madhav
symbols publish OK?
send an email to opendatakit...@googlegroups.com.
Now I understand why it was not published. I shall do the changes as you
suggested.
Thank you.
> sectionB/sectionC/sectionD1/cooler_no1
> sectionB/sectionC/sectionD2/cooler_no1
> sectionB/sectionC/sectionD2/cooler_no2
> sectionB/sectionC/sectionD3/cooler_no1
> sectionB/sectionC/sectionD3/cooler_no2
> sectionB/sectionC/sectionD3/cooler_no3
> the containing groups.
> an empty string.
> e.g.,
> sectionB/sectionC/sectionD1/cooler_d1_no1
> sectionB/sectionC/sectionD2/cooler_d2_no1
> sectionB/sectionC/sectionD2/cooler_d2_no2
> sectionB/sectionC/sectionD3/cooler_d3_no1
> sectionB/sectionC/sectionD3/cooler_d3_no2
> sectionB/sectionC/sectionD3/cooler_d3_no3
> Mitch
> On Thu, Aug 15, 2013 at 8:58 AM, Matt Berg <mlb...@gmail.com wrote:
>> I believe the XLSForm library on formhub has been updated to match.
>> U'kanga can you please confirm?
>> Thanks,
>> Matt
>>> Mitch
>>> On Thu, Aug 15, 2013 at 3:05 AM, Madhav <bblsu...@gmail.com wrote:
>>>> Thanks Mitch.,
>>>> Thanks!>
>>>>> Admin to your system and invite me as a developer. https://code.**
>>>>> google.com/p/opendatakit/wiki/**AppEngineTroubleshooting
>>>>>> Dear Mitch,
>>>>>> Madhav
>>>>>>> symbols publish OK?
>>>>>>> in the latest ODK Aggregate (the one with the entity-key fix) that is
>>>>>>> causing these actions to fail. We'll have a fix soon.
>>>>>>> Mitch
>>>>>>>> Hi,
>>>>>>>> created a sample form with barcode scanning and it works good and i can see
>>>>>>>> the value of barcode from ODK aggregate. when i tried to publish them to
>>>>>>>> fusion table the barcode value is turned blank. Also I couldn't export the
>>>>>>>> form data to csv or google spreadsheet, but aggregate is showing 'Not yet
>>>>>>>> Regards,
>>>>>>>> Madhav
>>>>>>>> Unsubscribe: opendatakit...@**googlegroups.**com
>>>>>>>> Options: http://groups.google.com/**group**/opendatakit?hl=en
>>>>>>>> For more options, visit https://groups.google.com/**grou**
>>>>>>>> ps/opt_out .
>>>>>>> Mitch Sundt
>>>>>>> Software Engineer
>>>>>>> mitche...@gmail.com
>>>>>> send an email to opendatakit...@**googlegroups.com.
>>>>> Mitch Sundt
>>>>> Software Engineer
>>>>> mitche...@gmail.com
>>>> an email to opendatakit...@googlegroups.com .
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
the
containing groups.
will be
is
an empty string.
reference
Thanks Mitch.,
could
tried with
Thanks!>
published
something ??.
Madhav
symbols publish OK?
in
causing
created
see the
to fusion
the form
yet
Thanks Mitch.,
Thanks!>
Madhav
symbols publish OK?
Nafundi has an unsupported feature in Collect 1.4 that drastically
improves the performance of very large itemsets. It's unsupported
because we haven't finished the changes to XLSForm that makes it easy
for normal folks to enable. If you are comfortable editing XML, email
me off list at yanokwa@nafundi.com and I'll send you the general idea.
Need ODK services? Go to http://nafundi.com for form design, data
cleaning, custom reporting, and software development for ODK.
ODK Collect most of the time. is there any workaround to handle such a large
Tks..
Madhav.
