Hello
What barcode scanner app (without pic2shop Barcode & QR Scanner) will run
on Samsung GT-P3100 tablet without autofocus camera?
I tried the 20 programs from Google Play. None scans. Is there any that
work properly on this tablet?
I want to integrate this barcode scanner with odk form.
Please assist me on this.
Hello
To add on what Justine is saying
We were nicely using Samsung Galaxy Tab 2 GT-P6200 which has auto focus camera and TEXT(micro) scene shooting mode to scan bar code.
We have now received Galaxy Tab 2 GT-P3100, its camera has no auto focus mode neither have TEXT(micro) shooting mode hence unable to read small size bar code.
The only android application that has proved to ready small size bar code with this device is SCANDIT, http://www.scandit.com/barcode-scanner-sdk/ but this application is not supported with ODK Collect
Could you please advice on how we can get it to work?
Advocatus
Hi Justine,
Are you also generating the barcode? If so, you can try to replace it with
QR code. It supposedly can be scanned without the need of auto focus.
Let me know if that works.
Guevara
On Saturday, May 24, 2014 4:48:26 PM UTC+3, Justine Govela wrote:
> Hello
Advocatus,
ODK uses the ZXing scanner. If you want to change that behavior,
you'll need to write Java code. You'll need to change the Intent call
at https://code.google.com/p/opendatakit/source/browse/src/org/odk/collect/android/widgets/BarcodeWidget.java?repo=collect#72
to whatever intent that Scandit supports. If Scandit doesn't have
Intent support, then you'll need to integrate their SDK instead.
On Mon, May 26, 2014 at 5:44 AM, akakorozya@gmail.com wrote:
Hello
Advocatus
Hello Yaw,
I am unable to check out the ODK collect source code using Git Bash when
running the following command;
hg clone https://code.google.com/p/opendatakit.collect/
with error message; sh.exe": hg: command not found
What could be the reason to it?
Kind regards,
Advo
On Tue, May 27, 2014 at 4:55 PM, Yaw Anokwa wrote:
Advocatus,
at
Hello
bar code.
Advocatus
https://groups.google.com/d/topic/opendatakit/UrTxK1ohlck/unsubscribe.
Advo,
The repo uses Mercurial (hg), not Git (git).
http://mercurial.selenic.com/downloads
On Wed, May 28, 2014 at 6:44 AM, akakorozya akakorozya@gmail.com wrote:
Hello Yaw,
Kind regards,
Advo
On Tue, May 27, 2014 at 4:55 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Advocatus,
at
Hello
bar code.
Advocatus
Hello Yaw,
Thank you for your quick response
I have managed to pull source code using eclipse Version: Indigo Service
Release 2
But when I import the project it comes with atleast 78 errors
Most of them are 1. CameraUpdateFactory cannot be resolved, 2.
DocumentContract cannot be resolved, 3. GoogleMap cannot be resolves
LatLng cannot be resolved, 4. Marker cannot be resolve and e.t.c
I have downloaded most of the the Libraries in the SDK manager with no
success
Regards,
Advo
On Wed, May 28, 2014 at 4:47 PM, Yaw Anokwa wrote:
Advo,
Hello Yaw,
Kind regards,
Advo
Advocatus,
at
Hello
focus
focus
small size
bar code.
not
Advocatus
Advo,
Make sure you are using Google API SDKs and Play Services.
http://code.google.com/p/opendatakit/source/checkout?repo=playservices
If you have any other code related questions, send them to
opendatakit-developers@googlegroups.com
On Fri, May 30, 2014 at 1:52 AM, akakorozya akakorozya@gmail.com wrote:
Hello Yaw,
Release 2
success
Regards,
Advo
On Wed, May 28, 2014 at 4:47 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Advo,
Hello Yaw,
Kind regards,
Advo
Advocatus,
at
Hello
focus
focus
small size
bar code.
not
Advocatus
send
Groups
an
