I'm running ODK Aggregate 1.4.6 on Google App Engine and ODK Collect 1.4.7
on my XPERIA Z3. I'm trying out the Bearing widget in a form. However, when
I try to send the finalised form to the server I get an error message from
ODK Collect. The error is "Internal server error (500)".
In XLSForms the prompt is defined:
TYPE: decimal, NAME: Bearing, APPERANCE: bearing. This is causing an error!
If i delete the value in the APPERANCE column, I can send the form without
any errors.
The log in App Engine will show:
org.opendatakit.aggregate.servlet.SubmissionServlet doPost: Unexpected
exception: null
when I'm using the Bearing widget.
Appearance shouldn't cause change in behavior on Aggregate. I just
tested with Collect 1.4.7 and Aggregate 1.4.5 and it worked great with
the attached form and submission.
any errors.
exception: null
Thanks for your answer. Unfortunately I'm getting the same problems when
using your XLSForm/Xform. When I delete the 'bearing'-value in the
APPERANCE-column, submission works as it should.
Since last post I have upgraded ODK Aggregate to version 1.4.7, but this
doesn't help, still same problem. I've enclosed my AppEngine logs for
Aggregate. When I upload a form I get warnings, and when I submit the same
form I get errors. See the attached file.
Form upload warnings:
W 19:21:18.623 org.opendatakit.aggregate.form.FormDefinition getSubmissionAssociation: No sa record matching this formId bearing
W 19:21:18.623 org.opendatakit.aggregate.form.FormDefinition getFormDefinition: No complete persistence model for sa record matching this formId bearing
W 19:21:19.278 org.opendatakit.aggregate.form.FormDefinition getSubmissionAssociation: No sa record matching this formId bearing
W 19:21:19.278 org.opendatakit.aggregate.form.FormDefinition getFormDefinition: No complete persistence model for sa record matching this formId bearing
Form submission error (last row):
I 19:22:36.193 org.opendatakit.aggregate.form.FormFactory internalGetForms: FormCache: fetching new list of Forms
I 19:22:36.269 org.opendatakit.aggregate.util.BackendActionsTable logValues: incoming- last Fetch: -23133 [S: -22964 Eq: -23133 Fs: -33645] futureMillis: 876867
I 19:22:36.292 org.opendatakit.aggregate.util.BackendActionsTable logValues: -fetched- last Fetch: 0 [S: -22964 Eq: -23133 Fs: -33645] futureMillis: -1
I 19:22:36.396 org.opendatakit.aggregate.util.BackendActionsTable logValues: Fs-update last Fetch: 0 [S: -22964 Eq: -23133 Fs: 876867] futureMillis: 876867 requested: 876867
E 19:22:36.415 org.opendatakit.aggregate.servlet.SubmissionServlet doPost: Unexpected exception: null
Sid
Den måndag 2 november 2015 kl. 04:29:49 UTC+1 skrev Yaw Anokwa:
> Sid,
> Yaw
> Need ODK consultants? https://nafundi.com provides form design, server
> setup, in-field training, and software development for ODK.
> 1.4.7
> when
> from
> error!
> without
> > any errors.
> > exception: null
> > Anyone got any ideas how to resolve this?
> Groups
> > "ODK Community" group.
> an
If you get a form upload error, then the submission will not work.
Try deleting the form definition. Then re-add it.
On Mon, Nov 2, 2015 at 11:13 AM, Sid Patel <4sidpatel@gmail.com> wrote:
Hi Yaw,
Sid
Sid,
1.4.7
when
from
error!
without
any errors.
exception: null
Groups
an
I've tried your solution and it doesn't work. However I've found that in
Yaw's example the response file uses decimal points and in my file decimal
commas are used for bearing values. That is probably because my device is
configured with swedish settings.
It appears that the bearing widget will use a decimal comma for swedish
devices, which seems to be incompatible with the decimal data type. Which
in turn generates an error when submitting the form to ODK aggregate.
If i edit the response XML file on the device, substituting commas for
points, form submission works as it should.
Is there a way to force ODK Collect to use decimal points in the bearing
widget?
Sid
Den måndag 2 november 2015 kl. 20:23:52 UTC+1 skrev Mitch Sundt:
> On Mon, Nov 2, 2015 at 11:13 AM, Sid Patel <4sid...@gmail.com > wrote:
>> Hi Yaw,
>> Sid
>>> Sid,
>>> Yaw
>>> 1.4.7
>>> when
>>> from
>>> error!
>>> without
>>> > any errors.
>>> > exception: null
>>> Groups
>>> an
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
I've pushed a fix for this - it will be in the next release.
On Mon, Nov 2, 2015 at 12:18 PM, Sid Patel <4sidpatel@gmail.com> wrote:
Mitch,
widget?
Sid
Sid
Sid,
1.4.7
However, when
from
error!
without
any errors.
Unexpected
exception: null
Groups
send an
Groups "ODK Community" group.
