Hi all,
My question is I want to input the name of all the family members of a family via 'Begin repeat'.
Let say in the first repeat the input name is "A" but in the second repeat if once again the name is given "A" then it should show the name is already given.
Is it possible to validate it??
Thanks for your reply.
Regards
Shadaab
if you can set a constrant by ussing following formula constraint=2<=.Count(name)
Shadaab,
And what if you have two people with the same name in the same family?
It's not uncommon...
Hi Saeem,
the code u gave is not working for me.
I tried to modify your code but it also didn't worked.
regards
shadaab
Hi Yaw,
U r correct that two people with the same name are common in a family but let there is an organisation of 3 members, if we input the member id of the members in a begin repeat and the 1st member entered his id as 1, then the 2nd member also entered the id 1 then it should show "invalid input" since member id with 1 is already been given. now is it possible to validate it??
regards
shadaab
could you send your xml?then i could solve the problem.
On Jan 17, 2014 12:09 PM, wrote:
Hi Yaw,
regards
shadaab
https://groups.google.com/d/topic/opendatakit/ZQGhFQ-wmAs/unsubscribe.
