I can connect to my server on the app and see my blank surveys, but when I try to dl'd them, I get the error pictured below.
ODK Collect, the latest version
Deleted and reloaded the app, checked my surveys, logged out and back in
Login and try to download the survey http://perunama.berkeleyair.com/ username: sdelapena password: gostoves
Oh, I see that yes. Any help on how to change that would be greatly appreciated! I already dropped the 's' in when logging into the server. Thank you!!!
Is there a reason that you can't or don't want to use a secure connection for your server? If you don't, anyone could potentially get access to the data you are collecting, modify it, send it to an unexpected place, etc.
Thank you for your reply, I installed, however, on Google Cloud and I don't think I can go back and alter the settings? Do I have to start from scratch again? If I do, can I still use the same subdomain? What would be ideal is if I could just get those surveys to upload without that pesky 's'! I don't mind if the server is secure or not.
The error on "connection refused" that you are getting i suspect is caused by some mis-configuration in the port used.
Your tomcat installation listens to port 80, it is important you configure this port during Aggregate configuration. If you decided to configure SSL, the default port that the installation will be listening to is 443.
At the moment i would advice you to start from scratch again and make sure to provide the same database credentials if you want to use the same database. Also, make sure you provide clearly the domain name during aggregate configuration ie: perunama.berkeleyair.com
Is changing the port something I can do when I build it again? Also, I don't think it goes over configuring SSL. Could the problem be with the subdomain I am using?
Hi all! I spoke to support at my host site (DreamHost) and they said they can't help, so I think it's a problem with my Google Cloud Platform setup. I started from scratch again like @dicksonsamwel suggested but i still get the same problem! Would anyone mind hopping on a Skype call to help? I's be happy to pay by the hour in PayPal or Venmo! Thank you!
