The message i always receive when trying to install odk aggregate vm is booting system without full network configuration, hence it will not assign ip address to the system. What should i do
albert
albert
Albert,
Sounds like the VM is on a network that did not assign it an IP. Make
sure the upstream router assigns IPs via DHCP. Alternatively, switch
the networking in the VM from Bridged to NAT, but then configure port
forwarding on the local computer to enable external connections to it.
Tomcat in the VM listens on port 80.
albert
