Does breifcase work for macs? I tried downloading it but can't seem to save
it to a specified storage location.
Rachel
Rachel
It should. What OS are you running?
Were you able to choose or change your Storage Location?
Also, it may be a permissions issue, as it needs to create several
directories to hold the data. Be sure you choose a location where you have
the rights to create directories / folders.
save it to a specified storage location.Rachel
I have used birefcase on macs (Lion and Mountain Lion) and it works just
fine.
I am using OSX V 10.7.5. An original storage location isn't specified when
the window pops up. I am able to change the storage location but I can't
find a location that works.
You should be able to create a new folder in the select-storage-location
dialog, and then choose that newly-created folder.
What errors do you get?
