I'm trying to export data through briefcase with the "Split select multiples" enabled and I get an error message
ODK Aggregate V2.0.1, Briefcase 1.14.0 (I also tested downloading data from and Aggregate 1.5.0)
- Launch Briefcase
- Pull data from Aggregate
- export with the option "Split select multiples" enabled
I tried with 2 version of Briefcase (1.14.0 and 1.13.1), 2 different version of Aggregate (2.0.1 and 1.5.0).
3 different forms.
Brifecase log:
2019-03-07 12:38:08,696 [Thread-15] ERROR o.o.briefcase.ui.export.ExportPanel - Error while exporting forms
java.lang.NullPointerException: null
at org.opendatakit.briefcase.export.Model.getNames(Model.java:162)
at org.opendatakit.briefcase.export.Model.lambda$getNames$0(Model.java:150)
at java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.util.stream.ReferencePipeline.collect(Unknown Source)
at org.opendatakit.briefcase.export.Model.getNames(Model.java:150)
at org.opendatakit.briefcase.export.CsvSubmissionMappers.getMainHeader(CsvSubmissionMappers.java:107)
at org.opendatakit.briefcase.export.Csv.main(Csv.java:59)
at org.opendatakit.briefcase.export.Csv.getCsvs(Csv.java:46)
at org.opendatakit.briefcase.export.ExportToCsv.export(ExportToCsv.java:87)
at org.opendatakit.briefcase.export.ExportToCsv.export(ExportToCsv.java:58)
at org.opendatakit.briefcase.ui.export.ExportPanel.lambda$export$8(ExportPanel.java:197)
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.util.stream.ReferencePipeline$11$1.accept(Unknown Source)
at java.util.stream.ForEachOps$ForEachTask.compute(Unknown Source)
at java.util.concurrent.CountedCompleter.exec(Unknown Source)
at java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.util.concurrent.ForkJoinTask.doInvoke(Unknown Source)
at java.util.concurrent.ForkJoinTask.invoke(Unknown Source)
at java.util.stream.ForEachOps$ForEachOp.evaluateParallel(Unknown Source)
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateParallel(Unknown Source)
at java.util.stream.ReferencePipeline.forEach(Unknown Source)
at org.opendatakit.briefcase.ui.export.ExportPanel.export(ExportPanel.java:183)
at java.lang.Thread.run(Unknown Source)
