Instances not pulling into ODK Briefcase Storage > forms > form name > instances folder when pulling
- MacOS Mojave
- ODK Briefcase - Tried 1.6.0 and 1.13.1
- Create temporary folder with the following subfolders: forms instances and metadata
- Extract instances from phones and place in the instances folder
- Place corresponding ODK forms in the forms folder
- Load ODK briefcase, and under Settings select the temporary folder as Storage Location (this will create a new folder in the temporty folder called ODK Briefcase Storage)
- Navigate to Pull menu in ODK Briefcase, select Pull from > Collect Directory
- Click Configure and select temporary folder
- Select all forms and Pull
- At this point, the forms folder held within the ODK Briefcase Storage folder will populate will the given forms. If the action executes correctly, the instances should populate under the ODK Briefcase Storage > forms > formname > instances folder. However, this is not happening
- Tried 2 different versions of ODK Briefcase.
- Tried to push to our server, hoping it would trigger something to happens.
