I definitely didn't migrate to hrd properly - I followed Google's
instructions - I didn't know about ODK's special instructions regarding the
migration process. I've just seen them. Oh no, I'm really panicking now, is
this something that can be fixed?
Hi Zach,
No need to panic. Could you add yanokwa@nafundi.com as an admin on
your Aggregate instance?
On Wed, Dec 19, 2012 at 7:18 PM, Zachary Burt wrote: > I definitely didn't migrate to hrd properly - I followed Google's > instructions - I didn't know about ODK's special instructions regarding the > migration process. I've just seen them. Oh no, I'm really panicking now, is > this something that can be fixed? > > > On Wednesday, December 19, 2012 9:51:10 AM UTC-8, Zachary Burt wrote: >> >> I'm not sure what changed - a couple of days ago I pulled my forms from >> Aggregate using Briefcase just fine. >> >> But this morning I tried to export those forms and it just froze while >> removing the encryption from the first instance. And just now when I tried >> to pull forms again, when I tried to log-in through the 'connect' window it >> just froze up without connecting. >> >> I have no idea what's going on with briefcase. Any help is much >> appreciated! >> >> Zach > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=enNo data is lost if you just migrated without the ODK process. It is all
still there. What is not accessible is the website because of a redirect.
On Wed, Dec 19, 2012 at 4:20 PM, Yaw Anokwa wrote:Hi Zach,
your Aggregate instance?Yaw
the
is
this something that can be fixed?On Wednesday, December 19, 2012 9:51:10 AM UTC-8, Zachary Burt wrote:
Aggregate using Briefcase just fine.But this morning I tried to export those forms and it just froze while
triedto pull forms again, when I tried to log-in through the 'connect'
window itjust froze up without connecting.
appreciated!Zach
This line:
Caused by: java.lang.SecurityException: The jurisdiction policy files are
not signed by a trusted signer!
Suggests that your cryptographic libraries are messed up after installing
the JCE. Note that there are different JCE files for Java 1.6 and Java
1.7. http://www.oracle.com/technetwork/java/javase/downloads/index.html
(down at the bottom).
I suspect you installed the 1.6 JCE on a 1.7 system.
On Wed, Dec 19, 2012 at 4:25 PM, Mitch S wrote:No data is lost if you just migrated without the ODK process. It is all
still there. What is not accessible is the website because of a redirect.On Wed, Dec 19, 2012 at 4:20 PM, Yaw Anokwa yanokwa@nafundi.com wrote:
Hi Zach,
the
now, is
appreciated!Zach
Mitch, I love you! you were correct, it worked!
On Wednesday, December 19, 2012 4:30:59 PM UTC-8, Mitch wrote: > > This line: > Caused by: java.lang.SecurityException: The jurisdiction policy files are > not signed by a trusted signer! > > Suggests that your cryptographic libraries are messed up after installing > the JCE. Note that there are different JCE files for Java 1.6 and Java > 1.7. http://www.oracle.com/technetwork/java/javase/downloads/index.html > (down at the bottom). > > I suspect you installed the 1.6 JCE on a 1.7 system. > > Mitch > > On Wed, Dec 19, 2012 at 4:25 PM, Mitch S <mitche...@gmail.com wrote: > >> No data is lost if you just migrated without the ODK process. It is all >> still there. What is not accessible is the website because of a redirect. >> >> >> On Wed, Dec 19, 2012 at 4:20 PM, Yaw Anokwa <yan...@nafundi.com wrote: >> >>> Hi Zach, >>> >>> No need to panic. Could you add yan...@nafundi.com as an >>> admin on >>> your Aggregate instance? >>> >>> Yaw >>> >>> On Wed, Dec 19, 2012 at 7:18 PM, Zachary Burt <zzb...@gmail.com> wrote: >>> > I definitely didn't migrate to hrd properly - I followed Google's >>> > instructions - I didn't know about ODK's special instructions >>> regarding the >>> > migration process. I've just seen them. Oh no, I'm really panicking >>> now, is >>> > this something that can be fixed? >>> > >>> > >>> > On Wednesday, December 19, 2012 9:51:10 AM UTC-8, Zachary Burt wrote: >>> >> >>> >> I'm not sure what changed - a couple of days ago I pulled my forms >>> from >>> >> Aggregate using Briefcase just fine. >>> >> >>> >> But this morning I tried to export those forms and it just froze while >>> >> removing the encryption from the first instance. And just now when I >>> tried >>> >> to pull forms again, when I tried to log-in through the 'connect' >>> window it >>> >> just froze up without connecting. >>> >> >>> >> I have no idea what's going on with briefcase. Any help is much >>> >> appreciated! >>> >> >>> >> Zach >>> > >>> > -- >>> > Post: opend...@googlegroups.com >>> > Unsubscribe: opendatakit...@googlegroups.com >>> > Options: http://groups.google.com/group/opendatakit?hl=en >>> >>> -- >>> Post: opend...@googlegroups.com >>> Unsubscribe: opendatakit...@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >> >> >> >> -- >> Mitch Sundt >> Software Engineer >> University of Washington >> mitche...@gmail.com >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >Hey Yaw, I think Mitch's suggestion has fixed the problem. THANK YOU BOTH
SO MUCH for your help!!! Today was so stressful for me, as I'm sure you can
imagine. I'm looking at my data and feeling much better now. I really
apologize for taking so much of your and Mitch's time for such a small
thing. He told me that I was using java 7 but JCE 1.6, which is a mis-match
and that I needed to use JCE 1.7 instead. It worked! - Zach
