In Build if under File you select publish to aggrate the export dialogue
only seems to have ... appspot.com.
Is is possible to publish (export) to one's own aggregate with a different
uri?
Or does one have to export to xml, save the xml file, browse to one's own
aggregate, go to form management, select add new form, select upload,
browse to saved location of saved xml.
It would make it easier if one could publish to ones own aggrate.
Please only ask questions once. It annoys me, and about 1000 other people
on the list to see a question posted multiple times.
uri?
