This is a post to help any devs who want to build ODK Collect in a consistent way, but may not regularly use Android Studio or Java.
Related to https://github.com/getodk/collect/pull/5928
I made a Github Gist that details how to run the test suite, check for linting errors, build and sideload APKs for testing. The post also details running the generated APK inside an emulated Android device, all using Docker:
Here is also an example Github workflow for building an ODK Collect APK via tag/release:
# Workflow to deploy custom builds on ODK Collect
name: 🔧 Build and Release
on:
release:
types: [published]
jobs:
build_upload_apk:
runs-on: ubuntu-latest
permissions:
contents: write
container:
image: docker.io/cimg/android:2023.10.1
steps:
- name: Checkout repository
uses: actions/checkout@v4
- name: Add Robolectric Deps
run: ./download-robolectric-deps.sh
- name: Compile Code
run: ./gradlew assembleDebug
- name: Install Github CLI
run: |
sudo apt update
sudo apt install --no-install-recommends -y gh
- name: Build & Upload APK
env:
GITHUB_TOKEN: ${{ secrets.GITHUB_TOKEN }}
run: |
./gradlew assembleSelfSignedRelease
apk_path=$(find ./collect_app/build/outputs/apk/selfSignedRelease -name '*.apk' -type f)
echo "Generated APK file: ${apk_path}"
gh release upload ${{ github.event.release.tag_name }} "${apk_path}"
