ODeeKers,
Working on building ODK from source and have run into a funky problem in
the ADT version of Eclipse.
I have a fresh version of ADT/Eclipse. Newest android SDK.
I cloned the most recent ODK Collect from the Repo.
Upon running eclipse, it complains:
[2014-04-07 16:35:04 - ODK Collect] Unable to resolve target 'Google
Inc.:Google APIs:19
So, I have used the SDK Manager to install API 19.
This allows you to import the project into Eclipse, but when you do, you
end up with quite a lot of errors.
I managed to fix 100+ errors by changing the “Build Target” from “Android
1.x to Google APIs 19” , and then using Project / Clean, Refresh, and Build.
I am still left with 679 errors, but this is just the first of them:
Description Resource Path Location Type
CameraUpdateFactory cannot be resolved GeoPointMapActivity.java /ODK
Collect/src/org/odk/collect/android/activities line 342 Java Problem
So, I am thinking that this is an issue that will be resolved if I install
the right API using the SDK manager, or maybe select the right Target. I
can't imaging that I will have to add each of these 679 missing resources,
and I imagine that I am not the only person to run into this issue. Is it
necessary to have other older APIs installed? Is it something about the
Java Build Path. Help me, Obi Wan Kenobi, you're my only hope.
Neil,
Make sure you have the Google Play Services extra installed as well. Then
quit and re-open Eclipse.
If that fails, switch to IntelliJ.
Need ODK services? http://nafundi.com provides form design, server setup,
professional support, and software development for ODK.
On Mon, Apr 7, 2014 at 3:36 PM, m0j0 TeXas mojotexas@gmail.com wrote:
ODeeKers,
Inc.:Google APIs:19
I managed to fix 100+ errors by changing the "Build Target" from
"Android 1.x to Google APIs 19" , and then using Project / Clean,
Refresh, and Build.
Good advice. I did check that Google Play services were installed. Did a
lot of clean/restart Eclipse. No dice.
So, I went ahead and installed IntelliJ. Nice interface, similar to
Eclipse, but less crufty I think. Still, I have a lot of the same errors.
I paste a few lines of the errors here:
Error:(40, 35) java: package com.google.android.gms.maps does not exist
Error:(41, 35) java: package com.google.android.gms.maps does not exist
Error:(42, 45) java: package com.google.android.gms.maps.GoogleMap does not
exist
Error:(43, 45) java: package com.google.android.gms.maps.GoogleMap does not
exist
IntelliJ has the same kind of integration for the SDK manager, so I am
attaching here a cap of the installed bits. What am I missing?
[image: Inline image 1]
☞§※☼:airplane:
~Neil
On Mon, Apr 7, 2014 at 7:32 PM, Yaw Anokwa wrote:
Neil,
Neil,
You've gotta add the Play Services project as a dependent module to
Collect. Then also include the Play Services lib.
http://www.jfarrell.net/2013/09/intellij-and-google-maps.html has a
good overview of how to do this.
And by the google play services project, we mean
http://code.google.com/p/opendatakit/source/browse?repo=playservices
On Tue, Apr 8, 2014 at 9:08 AM, Yaw Anokwa wrote:
Neil,
Now we are putting the Fun in Nafundi!
Thanks, that worked and allowed me to get past the errors, though there are
still a lot of warnings (139!). In the past, we haven't worrried about
these, so I am just moving ahead without worrying about the warnings.
☞§※☼:airplane:
~Neil
On Tue, Apr 8, 2014 at 12:08 PM, Yaw Anokwa wrote:
Neil,
https://groups.google.com/d/topic/opendatakit/PEjl-rM5Z94/unsubscribe.
Mitch,
Good tip! I already added the google play services as downloaded from the
SDK manager. Is that OK, or is the ODK Google Play Services special and
different?
☞§※☼:airplane:
~Neil
On Tue, Apr 8, 2014 at 9:08 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Neil,
The play services from the SDK revs slightly with every SDK update.
The authoritative build is with the one from that project, which we update
on our schedule, not Google's.
We also may have fiddled with some of the Android Lint settings of that
project to more easily get a signed APK; the dev environment doesn't
complain about many issues, but when you generate the signed APK, it can
sometimes crash and refuse to produce one.
On Tue, Apr 8, 2014 at 12:21 PM, Neil Hendrick wrote:
Mitch,
different?
☞§※☼:airplane:
~Neil
Neil,
