Most of my projects involve long forms and heavy amount of submission data. Hence, I have to put extra effort in form design, so that I don't have to go back and update it frequently. However, there are times when improvements are needed.
For a deployed form, I need to cluster together a set of similar-natured questions on a single screen. I can create a group around it and use field-list appearance, but the problem is that the group inserts a compulsory NAME variable in the set of variables (which effectively comes as a prefix to the already-existing variable names within that group). This disturbs a lot of things in the whole sequence of data processing and visualizing tools connected at the next hop of Central.
Is there a way to group questions less harmfully, without disturbing the already-running variable names sequence?
Happy to explain more if the above is not clear.
Cheers
