Hi All,
I am working on a from where if DOB is not known
i need to enter person age manually ie.. Age: 30
then based on age entered manually i need to auto calculate year of birth of that person.
ie.., year : 1989 should get displayed automatically
thanks in advance
Try the following:
birth_calculation.xlsx (8.8 KB)
| type | name | label | calculation | required |
| calculate | current_time | current_time | once(now()) | |
| calculate | current_year | current_year | format-date(${current_time}, '%Y') | |
| integer | age | Age (years)? | | yes |
| calculate | calculated_birth | calculated_birth | number(${current_year}) - number(${age}) | |
| note | display_calculation | The calculated birth year is ${calculated_birth} | | |
EDIT: see this post for a more accurate solution
Thank you.
It was helpful.
