Calculate not working because one data used for calculating irrelevant
Hello,
I'm having a hard time with a calculate issue.
One of the data used in the calculation is relevant only if it is answered yes to the previous question. If I answer "NO", the question doesn't appear in the survey. But then the calculation always indicates "0" as a result (whereas it is an addition).
Here are the details =
The calculate is
Calculate/ H27 = ${H11} * ${H13} + ${H20} * ${H21} + ${H24} * ${H25}
H20 is relevant if H19 = yes
H24 is relevant if H23 = yes
After, I add another calculate named
Calculate/ H28 = sum(${H27})
(note that it works because the H27 row is in a repeat)
So the calculate seems to be working, only when H20 and H24 are both relevant. Otherwise, the sum(${H27}) always indicates 0.
Thanks a lot for you help! You'll find attached the doc if it can help.
Cheers,
Charles
Quantitative_survey_extract.xlsx (27.2 KB)
Hi Charles,
If you can reduce this form to a few questions that show the problem,
I'm glad to take a look and see where the problem might be.
··· -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
On Sat, Aug 20, 2016 at 4:39 PM, c.teffo@gmail.com wrote:
Hello,
The calculate is
Cheers,
Charles
