Hi, I have a calculated field that is showed in a text field, in ODK
collect is not showed but it is calculated because when submitted to
formhub it is, in addition it is showed in Enteko, so it only fails in ODK
collect. I put below the part of the excel file that I use to collect the
data in formhub.
The columns are confusing. Anyway, is that a calculation "(likelihood +
severity2)" in a text field?
data in formhub.
email to opendatakit+unsubscribe@googlegroups.com
<javascript:_e(%7B%7D,'cvml','opendatakit%2Bunsubscribe@googlegroups.com');>
Nik
Need help customizing Survey Instruments/Tools/Forms for ODK Collect? Drop
me an email.
Hi, this is not a calculation, thats what is in the hint column, the
calculation is concat( ${s010101_severity},${s010101_likelihood}) and in
the text field I have put a reference to this calculated row in the label
column and in the calculate column, also I have tried with only the
reference in the label
in the text field I have put a reference to this calculated row in the
label column and in the calculate column, also I have tried with only the
