Calculating a scorecard
I have a question about using calculate to generate a score for each, based upon their answers to certain questions. I'm building the form in XLSform.
For the most part, the scores are generated using select_one questions with either a 'yes' or 'no' answer: we use 1 as the name (in choices) for 'yes' and 0 for 'no', then at the end we use calculate to add up the various scores (${Q1}+${Q2}+${Q3} ... etc). In addition, in some select_multiple select questions you get a point for each choice you select: we then use count-selected to get a score for that question.
All that works fine. But I now have two problems:
(1) We have a select_multiple question where although there are 8 choices, only two of those choices generate a point each for the scorecard. How can this be done? With selected-at, or substr?
(2) We have a select_one question with three choices: the best answer is worth two points, but the other two are worth one each. But if I was to use the select_one method described above, I'd have two answers with the name '1', which can't be done. So what's another way this could be done?
I have looked closely at the bindings page, however I don't know how to do XML ...
John,
Use intermediate prompts with calculates that get filled with whatever
value if a particular select has been chosen. If that choice has not
been made, then the value is 0.
Assuming you are using XLSForm, those calculates would look something like this:
favorite is red. value of this choice is 1
int(if((${favorite_color}='red'),1,0))
favorite is yellow. value of this choice is 2
int(if((${favorite_color}='yellow'),2,0))
Once you do that, you can sum up those intermediate prompts with those
values and get the points.
··· -- Need ODK services? http://nafundi.com provides form design, professional support, custom reporting, and software development for ODK.
Thanks so much Yaw. That's just the fix I was looking for.
··· On Sunday, September 22, 2013 11:26:15 PM UTC+9, John B wrote: > > I have a question about using calculate to generate a score for each, > based upon their answers to certain questions. I'm building the form in > XLSform. > > For the most part, the scores are generated using select_one questions > with either a 'yes' or 'no' answer: we use 1 as the name (in choices) for > 'yes' and 0 for 'no', then at the end we use calculate to add up the > various scores (${Q1}+${Q2}+${Q3} ... etc). In addition, in some > select_multiple select questions you get a point for each choice you > select: we then use count-selected to get a score for that question. > > All that works fine. But I now have two problems: > > (1) We have a select_multiple question where although there are 8 choices, > only two of those choices generate a point each for the scorecard. How can > this be done? With selected-at, or substr? > > (2) We have a select_one question with three choices: the best answer is > worth two points, but the other two are worth one each. But if I was to use > the select_one method described above, I'd have two answers with the name > '1', which can't be done. So what's another way this could be done? > > I have looked closely at the bindings page, however I don't know how to do > XML ... > >
Hi John,
Do you mind sharing your sheet, I am trying to do a simple calculation but
I am failing to comprehend the syntax.
Thanks and Regards
Ronald Munjoma
28 N Mandela Avenue, Harare
+263775625283
Sent using a mouse-sized keyboard with feigned autocorrect intelligence.
XLSform.
XML ...
