I have two date time elements within a form and I am looking to calculate the difference between the two (duration). Please can someone advise the best approach in order to achieve this?
Hi Damian,
I don't think that's possible. See
https://groups.google.com/d/msg/opendatakit/um9g921Qu1c/nHjlkM2rVFEJ
for some approaches that might work.
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Sun, Feb 23, 2014 at 11:41 PM, DamianLindley@aol.com wrote:
Additionally, I have since added
decimal-date-time(.) and decimal-time(.) which convert dates and times to
a
days.fractional-days
decimal value (like used inside Excel).
The intent was to allow formulas like:
decimal-date-time(${end})-decimal-date-time(${start})
to give you the elapsed fractional days of an event.
HOWEVER, because of additional logic in the bowels of the Javarosa
implementation to handle broken time zone treatments, it is now highly
likely that the time portion of a date-time value will be lost during any
and all calculations.
Be sure to test this extensively if you try to use it. Early reports are
that this is horribly broken.
On Mon, Feb 24, 2014 at 3:20 PM, Yaw Anokwa wrote:Hi Damian,
for some approaches that might work.Yaw
advise the best approach in order to achieve this?--
