I want to total a column in a repeat and compare the total with another
field prior to the repeat. I have a field called: Total Persons. And then
in the repeat, I have the following fields: Type of Settlement, Number of
Person, Status. The total of Number of Person should equal Total Persons.
email to opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>.
On Monday, January 27, 2014, Raul Maano wrote:
Nik
Need help customizing Survey Instruments/Tools/Forms for ODK Collect? Drop
me an email.
Nik
me an email.
Hi! I have the same problem. How did you apply the sum(nodeset) in the xlsx sheet?
Arnold Reyes
On Monday, January 27, 2014 9:18:13 PM UTC+8, Raul Maano wrote:
> Hi,
> I want to total a column in a repeat and compare the total with another field prior to the repeat. I have a field called: Total Persons. And then in the repeat, I have the following fields: Type of Settlement, Number of Person, Status. The total of Number of Person should equal Total Persons.
> How do I do this?
> Thanks.
> Raul
