Hi Mr Xiphware, ¿could you help me with the next problem? When I´m runnig the XLS Form, it shows me the next message:
Can you please post your original XLSForm to help correctly identify the exact cause of the error.
Of course, but in this moment the problem is another. I couldn't calculate multiples integer in a repeat option.
Help.xlsx (11.7 KB)
your two calculations - row 47, 48 - are outside the repeat group, but are attempting to directly reference fields inside the repeat group; this can only be done using an indexed-repeat() [otherwise how would you know which repeat iteration to grab the value from...]
Your form appears to be tallying the number of deliveries across various age/sex criteria. If you put a calculation inside the repeat to add up rows 6-18, say called ${subtotal}, then outside the repeat group you can have a single calculation ${total} = sum(${subtotal}) to give you the grand total. See sum() for details. I assume that's what you are trying to accomplish?
Yes, it is exactly what I'm trying to do, but ¿I could´t understand you very clear about what is the mistake that I have. Could you show me an example please?
Have a play with the following sample form. It shows how to calculate a subtotal within each repeat group instance, and then calculate an overall total using sum():
sumexample.xls (24.5 KB)
You can load and run it under XLSForm Online. Please note I assume all values are required so they must all be answered, otherwise you'll get 'NaN' as a total. If some of your summations are optional (which they will be if the associated question has a relevance field) then you will need to do some additional work to handle adding optional values.
Perfecto! Perfect!
Muchas gracias amigo! Thank you very much my friend!
Bendiciones! Bless!
Hi Xiphaware, I'm so sorry, I have a question again. I have a problem with my xls form, but it´s not exacly an error. In the same form, I want to show the subtotal and the item that I have been selected previously in a repeat cicle. I attached the sumexample.xls that you had shared with me and I had added another fields that explain better what I want to show in the form. ¿Would you help me, please?
sumexample_edited.xls (30 KB)
Sincerely,
Not clear your question but you can check the attached file. Let us know if it server your purpose.
sumexample_edited.xls (63.5 KB)
Thank you Arif, but I cpuld' resolve the situation. What I really want to show is that depend of the number of members that I have it shows me the one message about the member and the number of people of that kind of member. For example, if I selected 2 members of the family, the form shows me only the subotals and the member of each option, no more. I attached the example that I tryed to do. sumexample_edited.xls (31 KB)
Thank you for your help,
