Hi there,
Hoping someone can help - working in Excel.
Wondering what value I must put in a field if I want to divide? I would
like to substitute the (+) for a divide in the following equation > *
${mileage}+${age}*
Thank you
Hi there,
${mileage}+${age}*
Thank you
Imobi,
You can use "div" for divide. See the full list of operators here:
http://www.w3schools.com/xpath/xpath_operators.asp (and functions here:
https://bitbucket.org/javarosa/javarosa/wiki/xform-jr-compat#!paths-and-expressions
Chris
Hi there,
${mileage}+${age}*Thank you
Post: opendatakit@googlegroups.com <javascript:_e({}, 'cvml',
'opendatakit@googlegroups.com');>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:_e({},
'cvml', 'opendatakit%2Bunsubscribe@googlegroups.com');>
Hi Imobi,
For division you would use div. For example: ${mileage} div ${age}
Regards,
-Nathan
Thanks Chris
Imobi,
).Best,
Chris
On Monday, November 26, 2012, Imobi wrote:
Hi there,
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
Hi again,
It seems as though the calculation still does not work. Do you know why?
Please find attached my excel form; see J49
Thank you!
inspect_a_car.xls (32.5 KB)
Division by integers yields an integer result (truncated, not rounded).
From your form it looks like mileage could be a decimal which would then
cause the calculation to yield a decimal result. Does this explain the
problem you are having?
Hi again,
Please find attached my excel form; see J49Thank you!
On Tuesday, November 27, 2012 8:30:05 AM UTC+2, Imobi wrote:
Thanks Chris
On Mon, Nov 26, 2012 at 2:56 PM, Christopher Robert < Christopher_Robert@hks.**harvard.edu Christopher_Robert@hks.harvard.edu wrote:
Imobi,
http://www.w3schools.com/xpath/xpath_operators.asphttp://www.w3schools.com/xpath/xpath_operators.asp(and functions here:
https://bitbucket.org/**javarosa/javarosa/wiki/xform-
jr-compat#!paths-and-**expressionshttps://bitbucket.org/javarosa/javarosa/wiki/xform-jr-compat#!paths-and-expressions
).Best,
Chris
Hi there,
Unsubscribe: opendatakit+unsubscribe@**googlegroups.com
Options: http://groups.google.com/**group/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en--
Unsubscribe: opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
We are not getting any result at all, a decimal would be ok however
problem you are having?On Mon, Dec 3, 2012 at 10:58 PM, Imobi larisa@imobi.co.za wrote:
Hi again,
Thanks Chris
On Mon, Nov 26, 2012 at 2:56 PM, Christopher Robert < Christopher_Robert@hks.**harvard.eduChristopher_Robert@hks.harvard.edu wrote:
Imobi,
).Best,
Chris
Hi there,
would like to substitute the (+) for a divide in the following equation >
${mileage}+${age}Thank you
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
Sorry I can't check this out quickly but you might try putting spaces
around the operator "div" in your expression.
I've never see it all without spaces as you have it.
On Tue, Dec 4, 2012 at 9:25 AM, Gaetano Borriello < gaetano@cs.washington.edu> wrote:
Hi again,
Thanks Chris
Imobi,
).Best,
Chris
Hi there,
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Hi
I just tried adding the spaces in however than I am unable to convert it to
XLS. It gives the following error:
(without the spacing I do not receive an error)
Error: ODK Validate Errors: Invalid XPath expression
[/inspect_a_car/calculation/mileage div$ {age}]!
java.lang.NullPointerException java.lang.NullPointerException at
org.javarosa.core.model.FormDef.addTriggerable(FormDef.java:524) at
org.javarosa.xform.parse.XFormParser.processStandardBindAttributes(XFormParser.java:1501)
at org.javarosa.xform.parse.XFormParser.parseBind(XFormParser.java:1521) at
org.javarosa.xform.parse.XFormParser.parseModel(XFormParser.java:460) at
org.javarosa.xform.parse.XFormParser.access$200(XFormParser.java:78) at
org.javarosa.xform.parse.XFormParser$3.handle(XFormParser.java:153) at
org.javarosa.xform.parse.XFormParser.parseElement(XFormParser.java:375) at
org.javarosa.xform.parse.XFormParser.parseElement(XFormParser.java:386) at
org.javarosa.xform.parse.XFormParser.parseDoc(XFormParser.java:321) at
org.javarosa.xform.parse.XFormParser.parse(XFormParser.java:272) at
org.javarosa.xform.util.XFormUtils.getFormFromInputStream(XFormUtils.java:72)
at org.odk.validate.FormValidator.validate(FormValidator.java:322) at
org.odk.validate.FormValidator.(FormValidator.java:95) at
org.odk.validate.FormValidator.main(FormValidator.java:82) at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616) at
org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
On Tue, Dec 4, 2012 at 10:03 AM, Gaetano Borriello < gaetano@cs.washington.edu> wrote:
I've never see it all without spaces as you have it.On Mon, Dec 3, 2012 at 11:27 PM, Larisa Liepins larisa@imobi.co.zawrote:
Hi again,
why?
Thanks Chris
Imobi,
).Best,
Chris
Hi there,
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
It should be "${mileage} div ${age}" (without the quotes).
Hi
to XLS. It gives the following error:
(without the spacing I do not receive an error)Error: ODK Validate Errors: Invalid XPath expression
at
org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)Something broke the parser. See above for a hint. Result: Invalid
Hi again,
why?
Thanks Chris
Imobi,
).Best,
Chris
Hi there,
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688--
I added the spaces and displayed the result using a note. I have attached
the form which worked. Try it.
Mito
inspect_a_car.xls (38.5 KB)
Hi
er.java:1501) at
) at org.odk.validate.FormValidator.validate(FormValidator.java:322) at
) at
.java:43) at java.lang.reflect.Method.invoke(Method.java:616) at
a:58) >> Something broke the parser. See above for a hint. Result: Invalid
On Tue, Dec 4, 2012 at 10:03 AM, Gaetano Borriello <gaetano@cs.washington.edu mailto:gaetano@cs.washington.edu > wrote:
Sorry I can't check this out quickly but you might try putting spaces around
On Mon, Dec 3, 2012 at 11:27 PM, Larisa Liepins <larisa@imobi.co.za mailto:larisa@imobi.co.za > wrote:
On Tue, Dec 4, 2012 at 9:25 AM, Gaetano Borriello <gaetano@cs.washington.edu mailto:gaetano@cs.washington.edu > wrote:
On Mon, Dec 3, 2012 at 10:58 PM, Imobi <larisa@imobi.co.za mailto:larisa@imobi.co.za > wrote:
Hi again,
Thank you!
Thanks Chris
On Mon, Nov 26, 2012 at 2:56 PM, Christopher Robert <Christopher_Robert@hks.harvard.edu mailto:Christopher_Robert@hks.harvard.edu > wrote:
Imobi,
essions).
Chris
Hi there,
Wondering what value I must put in a field if I want to divide? I would like
${mileage}+${age}
Thank you
Post: opendatakit@googlegroups.com mailto:opendatakit@googlegroups.com
mailto:opendatakit+unsubscribe@googlegroups.com
mailto:opendatakit%2Bunsubscribe@googlegroups.com
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
When displaying fields on the same screen (field-list), value changes in
one field are not propagated through calculates or relevant conditions to
any of the other fields on the screen.
So if you are trying to display the calculated field value on the same
screen (field-list), as the values that feed into that formula, this will
not work.
You need to advance to a new screen to have those values propagate through
the formula and the calculated value be correct.
the form which worked. Try it.****
Mito****
From: opendatakit@googlegroups.com [mailto:opendatakit@googlegroups.com]
On Behalf Of Larisa Liepins
Sent: 04 December 2012 10:43 AM
To: opendatakit@googlegroups.com
Subject: Re: [ODK Community] calculation method - divide**
Hi****
to XLS. It gives the following error:****(without the spacing I do not receive an error)****
at
org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)Something broke the parser. See above for a hint. Result: Invalid****
gaetano@cs.washington.edu> wrote:****Sorry I can't check this out quickly but you might try putting spaces
around the operator "div" in your expression. ****I've never see it all without spaces as you have it.****
wrote:****Hi,
We are not getting any result at all, a decimal would be ok however****
Thanks****
gaetano@cs.washington.edu> wrote:****Division by integers yields an integer result (truncated, not rounded).
problem you are having?****
On Mon, Dec 3, 2012 at 10:58 PM, Imobi larisa@imobi.co.za wrote:****
Hi again,****
Please find attached my excel form; see J49****Thank you!
On Tuesday, November 27, 2012 8:30:05 AM UTC+2, Imobi wrote:****
Thanks Chris****
Christopher_Robert@hks.harvard.edu> wrote:****Imobi,****
Best,****
Chris
On Monday, November 26, 2012, Imobi wrote:****
Hi there,****
Hoping someone can help - working in Excel.****
${mileage}+${age}*****
Thank you****
Options: http://groups.google.com/group/opendatakit?hl=en****--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Thanks so much! got it working ![]()
Mito****
Hi****
at
wrote:****Hi,
Thanks****
Hi again,****
Thanks Chris****
Best,****
Chris
Hi there,****
Thank you****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
Thank so much for the help!
any of the other fields on the screen.So if you are trying to display the calculated field value on the same
not work.You need to advance to a new screen to have those values propagate through
the formula and the calculated value be correct.Mitch
Mito****
Hi****
at
wrote:****Hi,
Thanks****
Hi again,****
Thanks Chris****
Best,****
Chris
Hi there,****
Thank you****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
Larisa Liepins
O. 021 762 1661
C. 074 284 1688****
mitchellsundt@gmail.com--
Larisa Liepins
O. 021 762 1661
C. 074 284 1688
