Calculation on repeat inside another repeat
Hi ODK community,
I've been looking for solutions to my problem in the forum but I can't find anything. I don't know how to deal with it.
I am building a form to register the plots of one farmer and in each plot we register the species in it.
So the form is like this :
-Farmer info
-repeat plots (location)
-repeat species (species name, species number of trees)
So I have a repeat inside another repeat.
I want to sum the number of trees per plots. I add a calculate question inside the first repeat but unfortunatly whenever I register another plot, the calculate question also add the number of trees of the previous plot.
Here you have a simplified version of my form.
sum_on_repeat.xlsx (11.5 KB)
Any help would be highly appreciated.
Thank you
Hi and welcome, @Fabien_Pageot! Please take a moment to share a little about yourself and your project at Introduce yourself here! I'm guessing you already know @mathieubossaert and his work but if not, I think you would find ODK to collect species and habitats localities, as pressure and threats to ecosystems related to what you're doing.
I believe you are likely trying this form out in Enketo, is that right? I believe it will work as expected in ODK Collect.
It looks like the sum calculation is being output as sum(/data/plot_registration/species_registration/species_nb) from the XLSForm to XForm converter. However, it should be output as sum(../species_registration/species_nb). You should be able to change sum(${species_nb}) to sum(../species_registration/species_nb) in your XLSForm to get the desired behavior.
nested-repeat-sum is a further simplified form definition. The sum calculation is output as sum( /data/outer/inner/number ). @martijnr does this look like a pyxform bug to you as well?
Thank you a lot @LN !
I've changed sum(${species_nb}) to sum(../species_registration/species_nb) and now it works.
(However, I don't have access to the link nested-repeat-sum. )
Yes, indeed. Thanks. I created an issue for it here: https://github.com/XLSForm/pyxform/issues/453
