We have two questions (A_4_3_0 & A_4_3_1) within a group (A43). We put them inside a group because we want to display both questions in the same screen (we achieved this using field-list appearance). First question asks if the respondent knows how much money will he/she make. The second question asks for the amount of money. We want the latter to be required only if we have a yes as our previous response, that is why we tried the following:
Use ${question name}='yes value in choices wotksheet'
On 25 Jan 2016 09:28, wrote:
Dear ODK Community,
following:
ODK Collect does not recompute the relevance (visibility) of all the
questions on a screen as data is entered into those questions. As a result,
if you have Q2 relevance (visibility) depending upon an answer to Q1, and
both are on the same screen, Q2 will be visible or hidden based upon the
initial sate of Q1 when the combined screen is shown, and it will never
display until you leave and re-enter the screen, at which point the value
of Q1 will be re-examined and the Q2 will be made visible based upon Q1s
value at that time.
On 25 Jan 2016 09:28, pvicma@gmail.com wrote:
Dear ODK Community,
following:
ODK Collect does not recompute the relevance (visibility) of all the questions on a screen as data is entered into those questions. As a result, if you have Q2 relevance (visibility) depending upon an answer to Q1, and both are on the same screen, Q2 will be visible or hidden based upon the initial sate of Q1 when the combined screen is shown, and it will never display until you leave and re-enter the screen, at which point the value of Q1 will be re-examined and the Q2 will be made visible based upon Q1s value at that time.
Dear ODK Community,
Thank you very much, Mitch. Now I understand why it did not work.
