Noman,
See http://opendatakit.org/use/aggregate/data-transfer/#APIs
On Fri, Jan 24, 2014 at 12:58 PM, Noman Saleem noman.saleem.4@gmail.com wrote:
"ODK Developers" group.
Noman,
If you are confused, then you need to ask a more specific question
before anyone can help. Alternatively, hire help from
http://opendatakit.org/help/help-for-hire/.
On Sat, Jan 25, 2014 at 2:48 AM, Noman Saleem noman.saleem.4@gmail.com wrote:
On Friday, January 24, 2014 12:58:37 PM UTC-8, Noman Saleem wrote:
Thanks Yaw,yet i am confused!
Actually i am developing a "Form Generator" like "ODK Build" that will send
a form to ODK Aggregate for Survey through ODK Collect.
I just need to know how can i send this form(xml) to ODK Aggregate.
P.S. I am using ASP.Net
On Sat, Jan 25, 2014 at 8:12 AM, Yaw Anokwa wrote:
Noman,
https://groups.google.com/d/topic/opendatakit-developers/XCdqFLPsvfA/unsubscribe
Noman,
Submitting a form definition requires an HTTP post of the form def
(under the form_def_file parameter) to /formUpload (I think /upload
also works). I believe you can use HTTP Basic auth or OAUth.
See the Java example with basic auth in ODK Briefcase:
https://code.google.com/p/opendatakit/source/browse/src/org/opendatakit/briefcase/util/ServerUploader.java?repo=briefcase#267
Or see the Ruby example with OAuth in ODK Build:
https://github.com/clint-tseng/odkbuild/blob/master/odkbuild_server.rb#L213
Or see https://groups.google.com/d/msg/opendatakit-developers/Km99Tq_W3WM/dTyhoO-6ZUcJ
for a PHP example.
On Sat, Jan 25, 2014 at 11:28 AM, Noman Saleem noman.saleem.4@gmail.com wrote:
On Sat, Jan 25, 2014 at 8:12 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Noman,
Groups
an
https://groups.google.com/d/topic/opendatakit-developers/XCdqFLPsvfA/unsubscribe.
Thank you very much,I acknowledge your help
On Sun, Jan 26, 2014 at 8:37 AM, Yaw Anokwa wrote:
Noman,
Or see
for a PHP example.
send
Noman,
On Sat, Jan 25, 2014 at 2:48 AM, Noman Saleem <noman.saleem.4@gmail.com wrote:
Groups
an
