Dears,
Do we have a solution for this issue, because I face the same problem and I
want to know if it's possible with ODK Collect now.
I use the index-repeat function with position(..) inside my form designed
with excel but without success.
I try the same example designed here, but it's not working also.
Matayo
Le jeudi 6 juin 2013 16:09:23 UTC+2, abta...@gmail.com a écrit :
> I'm trying to do some simple addition and multiplication calculations
> within a Repeat group. The calculations function for the first entry, but
> fails for every additional entry. Can calculations function within repeats
> beyond the first entry? And if they can, how do you configure the
> calculation?
> Thanks,
> Will
Dear Matayo,
Calculations do work within repeat groups, and if even the sample form
doesn't work then perhaps you're running a version of Collect that doesn't
support indexed-repeat()? Are you running the latest version?
Also, the more detail you give, the more helpful people can be. For
example, you say that it's not working -- but how, exactly, is it not
working? And I'm assuming by "example" that you mean sample, but what
example do you mean? Be as detailed as you can and then you'll get the best
help. For example, if there is an error message, the exact details about
that error will be more helpful than just saying that there is an error
message. The people who help out in these forums thrive on details.
Chris
On Fri, Jul 18, 2014 at 3:46 AM, Stanyslas Matayo wrote:
Dears,
I want to know if it's possible with ODK Collect now.
Matayo
calculation?
Will
"ODK Developers" group.
Dear Christopher,
Thanks for your reply.
I try to calculate age for each person with details, It work for the first
person in repeat but the second one has the same age with the first, I work
with ODK Collect v 1.4.3 and XLSForm.
Please find attached the sample of my excel file where age is available.
Matayo
Vulnerabilty_Assessment_Sample.xls (518 KB)
2014-07-18 11:55 GMT+02:00 Christopher Robert :
Dear Matayo,
Chris
On Fri, Jul 18, 2014 at 3:46 AM, Stanyslas Matayo matayobweta@gmail.com wrote:
Dears,
Matayo
calculation?
Will
https://groups.google.com/d/topic/opendatakit-developers/7b3FohKkmRs/unsubscribe
Matayo,
There are no "calculate" fields (rows) in your attached form. Moreover, to
confirm, your "calculation" column is completely empty. Therefore, there
are no calculations. I also find no "age" fields.
You'll want to calculate the age within the same repeat group with the
birthdays. If you want to access those ages, then, outside the repeat
group, you'll need to use indexed-repeat().
Good luck,
Chris
On Fri, Jul 18, 2014 at 6:40 AM, Stanyslas Matayo wrote:
Dear Christopher,
Matayo
2014-07-18 11:55 GMT+02:00 Christopher Robert chrislrobert@gmail.com:
Dear Matayo,
Chris
Dears,
and I want to know if it's possible with ODK Collect now.
designed with excel but without success.
Matayo
calculation?
Will
an email to opendatakit-developers+unsubscribe@googlegroups.com.
Dear Christopher,
I sent a wrong document.
This is the good one.
Matayo
Assessment_Sample.xls (160 KB)
2014-07-18 12:46 GMT+02:00 Christopher Robert :
Matayo,
Good luck,
Chris
On Fri, Jul 18, 2014 at 6:40 AM, Stanyslas Matayo matayobweta@gmail.com wrote:
Dear Christopher,
first person in repeat but the second one has the same age with the first,
I work with ODK Collect v 1.4.3 and XLSForm.
Matayo
Dear Matayo,
Chris
On Fri, Jul 18, 2014 at 3:46 AM, Stanyslas Matayo <matayobweta@gmail.com wrote:
Dears,
Matayo
calculation?
Will
Matayo,
You don't need indexed-repeat() in this case, since the calculation is
within the same repeat group as the date that it uses. Thus, you can just
remove the indexed-repeat() and refer to the date of birth directly. It
should work fine.
Chris
On Fri, Jul 18, 2014 at 6:49 AM, Stanyslas Matayo wrote:
Dear Christopher,
Matayo
2014-07-18 12:46 GMT+02:00 Christopher Robert chrislrobert@gmail.com:
Matayo,
to confirm, your "calculation" column is completely empty. Therefore, there
Good luck,
Chris
Dear Christopher,
Matayo
Dear Matayo,
Chris
On Fri, Jul 18, 2014 at 3:46 AM, Stanyslas Matayo < matayobweta@gmail.com> wrote:
Dears,
Matayo
calculation?
Will
Dear Christopher,
Thanks for the support, i'll try it directly.
Matayo
2014-07-18 12:55 GMT+02:00 Christopher Robert :
Matayo,
should work fine.
Chris
On Fri, Jul 18, 2014 at 6:49 AM, Stanyslas Matayo matayobweta@gmail.com wrote:
Dear Christopher,
Matayo
Matayo,
Good luck,
Chris
On Fri, Jul 18, 2014 at 6:40 AM, Stanyslas Matayo <matayobweta@gmail.com wrote:
Dear Christopher,
Matayo
Dear Matayo,
Chris
Dears,
Matayo
calculations within a Repeat group. The calculations function for the
first entry, but fails for every additional entry. Can calculations
function within repeats beyond the first entry? And if they can, how do
you configure the calculation?
Will
send an email to opendatakit-developers+unsubscribe@googlegroups.com.
Dear Christopher,
I faced one problem before with the choice_filter before when I use direct
access to other field, I received one exception telling me that I should
consider using the index-repeat to fix this issues with choice_filter. When
I use index-repeat the exception disappear and everything gone well. If i
understand correctly your advice, this is not the case with calculation and
relevant?
Matayo
2014-07-18 12:57 GMT+02:00 Stanyslas Matayo :
Dear Christopher,
Matayo
2014-07-18 12:55 GMT+02:00 Christopher Robert chrislrobert@gmail.com:
Matayo,
should work fine.
Chris
Dear Christopher,
Matayo
Matayo,
Good luck,
Chris
On Fri, Jul 18, 2014 at 6:40 AM, Stanyslas Matayo < matayobweta@gmail.com> wrote:
Dear Christopher,
available.
Matayo
Dear Matayo,
form doesn't work then perhaps you're running a version of Collect that
doesn't support indexed-repeat()? Are you running the latest version?
Chris
Dears,
problem and I want to know if it's possible with ODK Collect now.
Matayo
Will
the Google Groups "ODK Developers" group.
Yes, correct. You can search the community group to find other solutions to
the choice_filter issue.
Chris
On Fri, Jul 18, 2014 at 7:06 AM, Stanyslas Matayo wrote:
Dear Christopher,
relevant?
Matayo
2014-07-18 12:57 GMT+02:00 Stanyslas Matayo matayobweta@gmail.com:
Dear Christopher,
Matayo
Matayo,
should work fine.
Chris
On Fri, Jul 18, 2014 at 6:49 AM, Stanyslas Matayo <matayobweta@gmail.com wrote:
Dear Christopher,
Matayo
Matayo,
Moreover, to confirm, your "calculation" column is completely empty.
Therefore, there are no calculations. I also find no "age" fields.
Good luck,
Chris
Dear Christopher,
available.
Matayo
2014-07-18 11:55 GMT+02:00 Christopher Robert <chrislrobert@gmail.com
Dear Matayo,
Chris
Dears,
Matayo
Will
send an email to
When using a repeated field to select a value from, e.g., a cascading
select, you will likely need to precede your use of ".." with "current()/"
in the XML, it should be:
instance('towns')/data/state[name=current()/../chosenstate]/towns
vs.
instance('towns')/data/state[name=../chosenstate]/towns
The problem with the last expression is that the ../ is evaluated relative
to instance('towns')/data/state, so you are referencing
instance('towns')/data/chosenstate instead of your form's chosenstate
field.
By using current()/, you are saying that you want the ../chosenform to be
evaluated relative to the field you are currently rendering (presumably the
select-your-town field).
On Fri, Jul 18, 2014 at 4:39 AM, Stanyslas Matayo wrote:
Dear Christopher,
Thanks, it's working.
Matayo
2014-07-18 13:09 GMT+02:00 Christopher Robert chrislrobert@gmail.com:
to the choice_filter issue.
Chris
On Fri, Jul 18, 2014 at 7:06 AM, Stanyslas Matayo matayobweta@gmail.com wrote:
Dear Christopher,
direct access to other field, I received one exception telling me that I
should consider using the index-repeat to fix this issues with
choice_filter. When I use index-repeat the exception disappear and
everything gone well. If i understand correctly your advice, this is not
the case with calculation and relevant?
Matayo
Dear Christopher,
Matayo
Matayo,
should work fine.
Chris
On Fri, Jul 18, 2014 at 6:49 AM, Stanyslas Matayo < matayobweta@gmail.com> wrote:
Dear Christopher,
Matayo
2014-07-18 12:46 GMT+02:00 Christopher Robert <chrislrobert@gmail.com
Matayo,
the birthdays. If you want to access those ages, then, outside the repeat
Good luck,
Chris
Dear Christopher,
the first person in repeat but the second one has the same age with the
first, I work with ODK Collect v 1.4.3 and XLSForm.
available.
Matayo
chrislrobert@gmail.com>:
Dear Matayo,
For example, you say that it's not working -- but how, exactly, is it not
Chris
Dears,
Matayo
Will
You received this message because you are subscribed to the
send an email to
send an email to
Dear Mitch,
Thanks a lot for this information
Thanks it's the way to do it with XSLForm?
And if it not possible what to add in excel file and what to change after
that?
Matayo
2014-07-18 19:36 GMT+02:00 Mitch Sundt :
vs.
field.
On Fri, Jul 18, 2014 at 4:39 AM, Stanyslas Matayo matayobweta@gmail.com wrote:
Dear Christopher,
Matayo
Chris
On Fri, Jul 18, 2014 at 7:06 AM, Stanyslas Matayo <matayobweta@gmail.com wrote:
Dear Christopher,
Matayo
Dear Christopher,
Matayo
Matayo,
is within the same repeat group as the date that it uses. Thus, you can
just remove the indexed-repeat() and refer to the date of birth directly.
It should work fine.
Chris
Dear Christopher,
Matayo
Matayo,
Good luck,
Chris
Dear Christopher,
available.
Matayo
Dear Matayo,
Chris
Dears,
Matayo
Will
it, send an email to
in the Google Groups "ODK Developers" group.
send an email to
Dear Mitch,
Sorry for the question, I get it.
Matayo
2014-07-19 0:20 GMT+02:00 Stanyslas Matayo :
Dear Mitch,
that?
Matayo
2014-07-18 19:36 GMT+02:00 Mitch Sundt mitchellsundt@gmail.com:
vs.
relative to instance('towns')/data/state, so you are referencing
field.
Dear Christopher,
Matayo
Chris
On Fri, Jul 18, 2014 at 7:06 AM, Stanyslas Matayo < matayobweta@gmail.com> wrote:
Dear Christopher,
Matayo
Dear Christopher,
Matayo
2014-07-18 12:55 GMT+02:00 Christopher Robert <chrislrobert@gmail.com
Matayo,
Chris
Dear Christopher,
Matayo
Matayo,
Good luck,
Chris
Dear Christopher,
available.
Matayo
Dear Matayo,
sample form doesn't work then perhaps you're running a version of Collect
that doesn't support indexed-repeat()? Are you running the latest version?
Chris
Dears,
form designed with excel but without success.
Matayo
écrit :
Will
send an email to
send an email to
Dear Mitch,
I observe that XSLForm generate an absolute path but your example use a
relative path, Please can you telle me how can I use your advice.
current()/form/.... or I should use /current()/form/.... or /form/ ....
/../current() ... Please advice which solution is the good one?
Matayo
2014-07-19 0:24 GMT+02:00 Stanyslas Matayo :
Dear Mitch,
Matayo
2014-07-19 0:20 GMT+02:00 Stanyslas Matayo matayobweta@gmail.com:
Dear Mitch,
that?
Matayo
vs.
field.
be evaluated relative to the field you are currently rendering (presumably
the select-your-town field).
On Fri, Jul 18, 2014 at 4:39 AM, Stanyslas Matayo <matayobweta@gmail.com wrote:
Dear Christopher,
Matayo
solutions to the choice_filter issue.
Chris
Dear Christopher,
Matayo
Dear Christopher,
Matayo
Matayo,
Chris
Dear Christopher,
Matayo
Matayo,
with the birthdays. If you want to access those ages, then, outside the
repeat group, you'll need to use indexed-repeat().
Good luck,
Chris
Dear Christopher,
available.
Matayo
Dear Matayo,
Chris
Dears,
also.
Matayo
écrit :
Will
send an email to
Can you share the solution please?
On Saturday, July 19, 2014 at 9:40:51 PM UTC+2, Stanyslas Matayo wrote:
> Dear Mitch,
> Solution found.
> Thanks
> Matayo
> 2014-07-19 7:38 GMT+02:00 Stanyslas Matayo :
> Dear Mitch,
> I observe that XSLForm generate an absolute path but your example use a relative path, Please can you telle me how can I use your advice. current()/form/.... or I should use /current()/form/.... or /form/ .... /../current() ... Please advice which solution is the good one?
> Thanks
> Matayo
> Dear Mitch,
> Thanks
> Matayo
> Dear Mitch,
> And if it not possible what to add in excel file and what to change after that?
> Thanks
> Matayo
> When using a repeated field to select a value from, e.g., a cascading select, you will likely need to precede your use of ".." with "current()/"
> vs.
> The problem with the last expression is that the ../ is evaluated relative to instance('towns')/data/state, so you are referencing instance('towns')/data/chosenstate instead of your form's chosenstate field.
> By using current()/, you are saying that you want the ../chosenform to be evaluated relative to the field you are currently rendering (presumably the select-your-town field).
> Dear Christopher,
> Thanks
> Matayo
> 2014-07-18 13:09 GMT+02:00 Christopher Robert :
> Yes, correct. You can search the community group to find other solutions to the choice_filter issue.
> Best,
> Chris
> Dear Christopher,
> I faced one problem before with the choice_filter before when I use direct access to other field, I received one exception telling me that I should consider using the index-repeat to fix this issues with choice_filter. When I use index-repeat the exception disappear and everything gone well. If i understand correctly your advice, this is not the case with calculation and relevant?
> Thanks
> Matayo
> Dear Christopher,
> Thanks
> Matayo
> Matayo,
> You don't need indexed-repeat() in this case, since the calculation is within the same repeat group as the date that it uses. Thus, you can just remove the indexed-repeat() and refer to the date of birth directly. It should work fine.
> Best,
> Chris
> Dear Christopher,
> Thanks
> Matayo
> Matayo,
> There are no "calculate" fields (rows) in your attached form. Moreover, to confirm, your "calculation" column is completely empty. Therefore, there are no calculations. I also find no "age" fields.
> You'll want to calculate the age within the same repeat group with the birthdays. If you want to access those ages, then, outside the repeat group, you'll need to use indexed-repeat().
> Good luck,
> Chris
> Dear Christopher,
> I try to calculate age for each person with details, It work for the first person in repeat but the second one has the same age with the first, I work with ODK Collect v 1.4.3 and XLSForm.
> Thanks
> Matayo
> Dear Matayo,
> Calculations do work within repeat groups, and if even the sample form doesn't work then perhaps you're running a version of Collect that doesn't support indexed-repeat()? Are you running the latest version?
> Also, the more detail you give, the more helpful people can be. For example, you say that it's not working -- but how, exactly, is it not working? And I'm assuming by "example" that you mean sample, but what example do you mean? Be as detailed as you can and then you'll get the best help. For example, if there is an error message, the exact details about that error will be more helpful than just saying that there is an error message. The people who help out in these forums thrive on details.
> Thanks,
> Chris
> Dears,
> Do we have a solution for this issue, because I face the same problem and I want to know if it's possible with ODK Collect now.
> I use the index-repeat function with position(..) inside my form designed with excel but without success.
> Thanks
> Matayo
> I'm trying to do some simple addition and multiplication calculations within a Repeat group. The calculations function for the first entry, but fails for every additional entry. Can calculations function within repeats beyond the first entry? And if they can, how do you configure the calculation?
> Thanks,
> Will
> You received this message because you are subscribed to the Google Groups "ODK Developers" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
> You received this message because you are subscribed to a topic in the Google Groups "ODK Developers" group.
> To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit-developers/7b3FohKkmRs/unsubscribe.
> To unsubscribe from this group and all its topics, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
