Does ODK have a provision to warn an enumerator about, but not prevent
them from entering, a value that is likely a data-entry error, but may
simply be a true outlier? We would like enumerators to be told by ODK
that a value appears incorrect, but allow them to enter it anyway, if
it can be confirmed.
For example:
-- enumerator enters # (100) for number of children in a classroom,
this falls outside of a constraint (maximum 40)
-- ODK window pops up saying: the response you entered may be an
error. can you check it and choose one of the following:
a) (if it's an error) enter a different response
b) (if it's correct) keep the response as previously entered
You can, however, add a confirmation question afterward that is relevant
only if the value is an outlier.
That confirmation question can either be (1) an informational read-only
field that the enumerator can blow through if they want, or (2) a required
select1 that defaults to "no", but is constrained to "yes" and therefore
requires the enumerator to select the "yes" in order to keep the outlier,
thereby getting their acknowledgement that this is a valid outlier.
A bit clunky, but gets the job done.
For example:
assuming I take the second approach that you mention (adding a y/n):
the "yes" is clear (the user confirms it's a true outlier) but what if
it's a "no" (the user acknowledges that they've made a data-entry
error). Then what? Can I program ODK to "send" the user back a
question to re-enter the preceding response? I don't know how to do
this...
edwin
On Oct 28, 2:43 pm, Mitch Sundt wrote:
> Not as pop-ups like a hard constraint.
> Mitch
> > For example:
> > is that do-able?
> > thanks,
> > Edwin Adkins
> Mitch Sundt
> Software Engineerhttp://www.OpenDataKit.org
> University of Washington
> mitchellsu...@gmail.com
On Wed, Nov 2, 2011 at 2:00 PM, Edwin Adkins wrote:
ok, many thanks for the reply.
one follow-up question:
this...
required
For example:
you can either tell the user to swipe back, or you can have them
re-enter the value inside a new widget.
if this is prompt that can be asked another way, one survey design
trick is to ask a related question that helps you figure out if the
first question was correct. so you ask for age, then a few questions
later ask for birth year.
On Thu, Nov 3, 2011 at 03:49, Mitch Sundt wrote:
> I don't think that's possible. Yaw - thoughts?
> Mitch
>> this...
>> edwin
>> > required
>> > outlier,
>> > Mitch
>> > > For example:
>> > > is that do-able?
>> > > thanks,
>> > > Edwin Adkins
>> > Mitch Sundt
> Mitch Sundt
> Software Engineer
> mitchellsundt@gmail.com
You could constrain the second question to only accept an answer of "yes"
and make the constraint text something along the lines of, "please go to
the previous question and change your answer", but you can't explicitly
jump backwards to a certain question.
this...
prevent
may
ODK
if
For example:
