Hi ODKers
I have problems when using the form on repeat cascade feature,
for the first filling is no problem, but when filling the second one I have
problems "you may need to use the indexed-repeated() function to specify
which value you want"
https://lh6.googleusercontent.com/gAeKjEar034MqKw7hn5Y56nPN6Fn_Ve0PRtUYOEebKR1eJ5577cusaVe30GMrkapsCeBxA=s400
atlasburungindonesia_cascade_LL.xls (214 KB)
Laurio,
The problem is probably the use of the choice_filter. Try removing that and
see if that works. What else have you tried as a workaround?
Need ODK consultants? Nafundi provides form design, server setup, in-field
training, and software development for ODK. Go to https://nafundi.com to
get started.
On Thu, Feb 25, 2016 at 2:37 PM, Laurio Leonald laurioleonald@gmail.com wrote:
Hi ODKers
Hi Yaw,
Yeah, the problem is the choice_filter (cascading), but I need the cascade
fiture to make simple view the to much choices.
R
2016-03-11 22:03 GMT+07:00 Yaw Anokwa :
Laurio,
and see if that works. What else have you tried as a workaround?
get started.
Hi ODKers
https://groups.google.com/d/topic/opendatakit/QgySE7eVK_8/unsubscribe.
If you need this, you will need to become familiar with the
slightly-non-conformant implementation of XPath expressions within ODK
(javarosa).
Search the list for postings relating to current(), position(.), and XPath
to find some information on these.
On Mon, Mar 14, 2016 at 8:57 PM, Laurio Leonald wrote:
Hi Yaw,
R
2016-03-11 22:03 GMT+07:00 Yaw Anokwa yanokwa@nafundi.com:
Laurio,
Hi ODKers
specify which value you want"
