Hi all,
i have implemented a cascading Select using XLSForm of States, Counties and
cities. the list is very long as you can imagine.
unfortunately after the form has been filled and closed it does not save
the selections made to the States nor Counties nor cities.
Thank you
Abdul
new_cascading_select.xls (227 KB)
Abdul,
It looks like it saves the data to XML but doesn't load it back up.
Values should not contain spaces or apostrophes, but labels can. My
guess is that is what is screwing it up.
Try reducing the form to a few states, counties and cities with no
spaces and see if that works. Attached is a sample I used for Vietnam.
Vietnam.xlsx (33.6 KB)
On Tue, May 20, 2014 at 6:47 AM, Abdul Cassamo wrote:
> Hi all,
> unfortunately after the form has been filled and closed it does not save the
> Thank you
> Abdul
> "ODK Developers" group.
> email to opendatakit-developers+unsubscribe@googlegroups.com.
hi Yaw,
it was indeed the variable names. i really appreciate you help.
Take care
Abdul
On Tuesday, May 20, 2014 4:00:14 PM UTC+2, Yaw Anokwa wrote:
> Abdul,
> Yaw
> On Tue, May 20, 2014 at 6:47 AM, Abdul Cassamo <cass...@gmail.com> wrote:
> > Hi all,
> and
> the
> > Thank you
> > Abdul
> Groups
> an
Abdul,
Glad to help! In the future, use ODK Validate
(http://opendatakit.org/downloads/download-category/validate/) to test
the form. It catches these sorts of mistakes.
On Wed, May 21, 2014 at 8:13 AM, Abdul Cassamo cassamoar@gmail.com wrote:
hi Yaw,
Take care
Abdul
Abdul,
On Tue, May 20, 2014 at 6:47 AM, Abdul Cassamo cass...@gmail.com wrote:
Hi all,
and
the
Thank you
Abdul
Groups
an
