Cascading selects not working
Hello,
I did the cascading following each steps mentioned in the
new_cascading_select.xls file. But its not working. Any help?
I added the cascading as select_one district and in the choice_filter
column
state=${state}.
Semira,
Download the examples at http://xlsform.org/#cascade or
https://gumroad.com/l/odk-form-design-tips. Those should work out of
the box. Build on those examples.
··· -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
On Wed, May 11, 2016 at 12:22 PM, semira Abdelmenan semiramenan@gmail.com wrote:
Hello,
I did the cascading following each steps mentioned in the new_cascading_select.xls file. But its not working. Any help?
I added the cascading as select_one district and in the choice_filter column
state=${state}.
Hello!
I have a very simple cascade that I created in one xls, and converted without an issue into an XML :heart_eyes:
This cascade is your generic States > County with only 25 rows.
The cascade needs to be on six separate forms, and when I copy/pasted it onto other xls forms, when I went to convert, I received the following message:
Error: 'list' object has no attribute 'startswith'
Me and another extremely experienced ODKer reviewed in fine detail the entire form and confirmed there were no typos in the copy/pasted form and I additionally have reviewed all ODK posts related to cascades and additionally Nafundi's gumroad.com template to confirm any possible errors on my end.
I believe that there might be an issue related to a UTF conversion issue for the opendatakit.com/xiframe site. Any help or insights would be extremely appreciated
Please upload a copy of your form with the minimum number of questions that causes the problem so others can help troubleshoot!
